First post, by Jackhead
I bought a ASUS P/I-P55T2P4 Rev 3.1 as broken and try to repair it.
So from the seller the error description is no picture.
First test when i got the board indeed no picture. I testet with 2 different GPUs a PCI and ISA one.
Than i connected a Speaker and i got no beeps on power up. Tested 2 different CPUs a 200MHz Pentium and a 233.
After that i start replacing the Caps and the Dallas battery. Still nothing...
Last try was reflashing the bios Chip with the latest bios for the board from 1999.
When i power on the system, the CPU and other chips get temprature.
Jumpers are all set with the manual.
Anyone an idea? Maybe something typical for socket 7?
Reply 1 of 7, by BitWrangler
Two things I would try... Clear CMOS, so it knows it hasn't got settings and put some basic ones in there. Then secondly, some Asus boards for OEMs were set up with a soft power up mode that required tapping the space bar on keyboard. You can turn that off after you get into CMOS setup, but first you have to get that far.
Reply 2 of 7, by Jackhead
I did clear CMOS before with the on board jumper, and removing the battery.
Ordered a ISA/PCI testcard for an error code, hope that will help finding the issue, never tryed such testcard..
There is zero signal from the GPU. I think the bios did not init.
Will also replace the two 9636 mosfets.
Reply 3 of 7, by BitWrangler
After the new battery is in, it might have random settings, so unless you clear it then, you're trying to start with random settings. Particularly in the case of Dallas/Odin modules where the CMOS RAM is inside that module and the battery in it is holding whatever has ended up in that while being shipped around, hit by cosmic rays and being poked by airport Xray machines.
Reply 4 of 7, by Jackhead
I got that testboard today, plugged in a pci slot it shows me a short on the 3.3V line.
Reply 5 of 7, by rasz_pl
POST cards cant show shorts, only somewhat signal if a power rail has some voltage in the ballpark. What you are most likely seeing is lack of 3.3V on PCI slot, which is normal. Early PCI was all 5V, transition to 3.3V happened around 1999.
start with basics. Multimeter/scope and measure voltages. 5V in ISA/CPI/simm slots. CPU Vcore and Vio.
Next is, or rather are Reset signals. Starting with reset on ISA slot pin B2 (between ground and power)
Then look under good magnification and toothpick at all PIIX3 pins, and in general carefully look the board over for missing/cracked small SMD components and scratches both sides.
Then measure Resets directly on southbrisge PIIX3 https://mark-ogden.uk/files/intel/publication … rator-May96.pdf pins 127 cpureset, 128 pcireset, pin 126 PWROK, pin 28 RSTDRV
Then scope needed to check if clocks gen is running and producing 14.31818MHz for PIIX3 and whatever the CPU clock is.
Then scope/logic probe on BIOS address/data pins to see if any activity is taking place at all.
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 6 of 7, by Jackhead
Thanks for the help!
Thats a lot of testing, i did the follow tests:
First as you say i checked all the pins on my ISA/PCI/SIMM connections against power/GND. Anything fine here, no short on any powerline in this part of the board.
Than i checked the voltage regulator that should transform the 5V to 3.3V near the cpu. The incomming 5V there are shorted to GND.
I desoldered the converter and he is ok. Without the converter is still a short between 5v/GND.
Next test i did is the clock on the crystal, and 14,32 is there.
New battery 3V to GND ok.
So the CPU pins and the PIIX3 is open to check. For that i need to prepare some stuff.
Reply 7 of 7, by rasz_pl
Jackhead wrote on 2026-06-04, 11:46:
wait, you cant have good 5V on ISA slot but shorted 5V feeding the CPU Vio regulator. There is only one common 5V circuit on the board. Shorted 5V would make PSU automagically shut off instantly or burn the short out with visible smoke.
