First post, by stanwebber
i use fastlynx as a convenience to transfer files between 2 systems that are already connected for serial midi output from softmpu. it works great in both dos and win95/98 and i use a full 7-wire null modem cable that supports the highest throughput. in the past i had a 10 meter cables-to-go null modem cable and probably transferred 100's of mb over the years at 115kbps (7-wire accelerated) with never a hiccup. how i wish i had held onto that cable, but the distance to be traveled was under 1 meter so i replaced it with a shorter cable.
to give myself future flexibility i opted for rs232 to rj45 adapters that you can pin yourself so i could use off-the-shelf cat5a patch cables. i pinned 1 adapter straight thru: rs232 pin 1-8 to rj45 pin 1-8 and manipulated the pins in the other adapter for a full 7-wire null modem. this worked, but not consistently. i could transfer small files ok, but if the files were of any significant size the transfer would abort unpredictably. i thought maybe the cat5a twisted pairs were causing interference since i just pinned it straight thru 1-8 so i re-pinned both adapters using a strategy to separate the related communication wires as far apart as possible. the result was exactly the same as before (even swapping out numerous cat5a cables).
at this point i gave up and purchased a retail 1 meter null modem cable from rocstor.com--same result as the cat5a patch cables! ok, i don't know anything about rocstor's reputation so let's try a startech.com branded 1 meter cable. again, no difference! what is going on? how is a 10 meter cable outperforming 3 other cables a tenth the length? how much shielding could there have possibly been in that 10 meter cable? it's only 1 meter of travel...can the crosstalk be that bad on the short cables?
did i just get extremely unlucky with crap cables or am i overlooking something? null modem serial transfer is a simple proposition so there isn't a whole lot of configuration options in fastlynx. it's possible, but i doubt if i got any of the settings mismatched/wrong. it has been close to a decade since i used that 10 meter cable between these same 2 systems so maybe something else has changed that i'm not considering?
