First post, by RetroViator
- Newbie
I was gifted a lovely Dell System 310 when the IT guys at my office were cleaning out an old closet. I was disappointed to get it home and find that it's motherboard had been replaced with an AMD K6. However, a long-term eBay alert paid off, and I now have a System 325 board that fits this tank of a case. (The System 310 was a 386DX running at 20MHz and the 325 ran at 25MHz.)
After I replaced bad ceramic caps on the +12V and -12V power rails, it powers up, but the CPU is not running. When checking for shorts before powering it on, I discovered that a short on the +5V rail disappeared when I removed the Intel 82385 cache controller. I bought another 82385, and the short remained. So, perhaps the CPU is not running because I've left the cache controller out.
I wondering if the cache controller was in the correct orientation when I got the motherboard? The only picture I can find is the one I uploaded to https://theretroweb.com/motherboards/s/dell-system-325. Unfortunately, the motherboard lacks any indication for pin 1. I have been checking the VCC and VSS pins, and they are not lining up with the datasheet. This could mean a problem on the board, or I am not looking at it correctly.
Perhaps I'll get lucky and someone with a System 325 can help out.
