First post, by markpot4
I have issues with the s3 onboard graphics. It freezes randomly when building graphics (playing a game, swiching windows etc). It also sometimes already freeze in the vga bios when switching between bios windows. When the freeze happen the pc stop building graphics or text. The "-" still blinks during the freeze but but the text or garpahics doesnt progress further (see picture). So it feels like the gpu isnt completly frozen it just is waiting for a awnser from the graphic that it never gets.
When using a isa graphic card it works without issues but isa speed is a lot slower then the s3 onboard chip so it would be still nice to get the s3 onboard chip to work.
The cpu seems to be upgraded to an cpu 486dx 50mhz instead of a 486sx that came with the board. Dont know if this could make any issues. Deactivate l1 cache make the graphics more stable and less freezes happen. There are still freezes happening but not as much as with l1 cache on. I think thats bc the cpu is working much slower with l1 cache off.
Also I realized there are some kind of graphical noise. The noise gets worse the more you turning up color depth in win95. Especially when using true color mode in win95. I dont have the noise with the isa graphic card. Also at the point while the pc is testing himem there is a lot of graphical noise going on. However I have no color issues, text issues or anything else. When the freezes happen the noise itself is still going on and doesnt freeze. So seems like the graphics itself are still working during the freeze.
The bios dallas rtc chip battery is low btw. It has no corrosion bc its inside a chip. Dont know if this have to do something with the issue bc its connected with the vga bios chip that controls s3 graphics. There are 2 bios chips on the board btw. 1. Award Software inc bios chip 2. Quadtel bios software vga chip. Seems like one is for the bios itself and the other one for the graphical bios or something.
I also run checkit to test everything. It have almost no issues. Ram, cpu, hdd, chipset-test run fine. Only the vga test freezes when building graphics. First I thought its the vram maybe but the vram test on checkit run mostly without issues. Only one time it freezes and there was a black and white pattern while freezing. But im not sure if the problem was the vram itself or something else during the vram test that triggers the freeze.
Does someone maybe know what could cause these freezing issues and does those graphical have to do something with the freezes or is this a seperate problem (maybe vga cable problem or something).
I also uploaded a picture of the mainboard btw maybe that helps for diagnose the issue.
Reply 1 of 18, by MagefromAntares
Hi,
I'm not familiar with this exact motherboard and I cannot find a tech manual or datasheet on any reliable website I know of. However I think you can rule out the VGA cable problem if the graphics freezes the way like on the second picture. VGA cable faults don't cause issues like this, from that single picture it seems that the problem is with updating the video memory, the characters seem to be outputting correctly(No corrupt or weird characters), but the writing into text mode VRAM just stopped.
A low BIOS battery whether inside a Dallas chip or outside can cause weird issues, but it would be strange that it works 100% properly with an ISA card and fails with the onboard chip(Not unheard of though), but if the Battery voltage is low expect it to be needed to be replaced after a while anyway.
The CPU seems to have thermal paste covering it, did it come with a cooler or heatsink that was removed? IIRC the DX-50 doesn't really need a heatsink as it has somewhere around ~5W TDP, but if it originally had one why it was removed?
EDIT: Can you make a closer picture of the S3 chip or write down the exact type of it, I cannot make out from the first picture what is the exact type of that S3 chip, I would guess this one:https://theretroweb.com/chips/3945, which was used in 486 class motherboards, but I cannot be sure the picture detail is simply too low to make it out.
"A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it." - Dune
Reply 2 of 18, by Law212
Maybe if the CPU is upgraded from an SX 25 or 33 then the jumpers arent correct for the new CPU causing timing issues?
possibly the onboard vram is bad since isa cards work you said?
clean the cpu off it hurts to see it covered in goop
Reply 3 of 18, by rasz_pl
> 486dx 50mhz
I was gonna say this is your problem, but then I found your posts at https://forum.classic-computing.de/forum/inde … ezing-probleme/
https://forum-classic--computing-de.translate … &_x_tr_pto=wapp
I would start by fixing original RTC module battery, and testing with second PSU (5V might be noisy)
theretroweb doesnt have Unisys 4253sx 🙁
Reply 4 of 18, by markpot4
I changed the dallas chip to a new chip with a working battery. Of course it solved all my checksum errors but the freezes still occur. The weird thing is that when i underclock my cpu from 50mhz to 33mhz the freezes appear even more often. So 50mhz is somehow more stable. When turning l1 cachr off it also make the graphics a bit more stable.
What I think could be the problem:
1. Maybe Broken vram? However vram tests with checkit working fine. So maybe there is a vram cell that sometimes work and sometimes fail?
2. Borken ramdac (the chip that convert digital to analog input)?
3. Broken Avmem chip (clk-generator for the s3 chip)
4. Broken tantal capacitor or broken filter coil.
Reply 5 of 18, by MagefromAntares
markpot4 wrote on 2026-06-10, 13:04:
If the VRAM is dual ported, it is possible that it has problem with the part that connects it to the S3 chip, but works properly with the CPU side, check the VRAM chips if they are dual ported or not, I cannot see them enough from the picture.
Unlikely as a broken RAMDAC would almost always cause colour issues.
Possibly, if you have an oscilloscope you can check the output.
I would consider this to be less likely than the VRAM or CLK-Generator problem, but still possible.
Reply 6 of 18, by rasz_pl
afaik there is no new, only very old shock, remarked chips, and clones/fakes. Thats why I suggest _fixing original RTC module battery_
saw that in the German forum, weird
tantalums break spectacularly, you would know 😀
_test with second PSU_, 5V might be noisy in the old one. You can also whip out oscilloscope and start measuring around.
Reply 7 of 18, by markpot4
Ive spend the last months trying to find out whats wrong in the pc.
Ive doing a lot of tests and benchmarks, testing another power supply, resolder some solder joints, changed some tantql capacitors but nothing solved the propblem.
I think its also not the onboard graphic bc it also freezes with the isa vga card. But using the onboard graphic casues the freezes to appear more often than with a slower isa-vga card. The only thing thats better with the isa vga card: there are no graphical noise anymore.
I think there could be also somehting wrong with the cpu-clk generator. Because diffrent clock cause freezes to appear more or less often. And with some clk settings (25mhz) the pc dont even posts. Also sometimes before a freeze I get a devide error and the program crashes. Also sometimes I get some corrupt data or filenames.
So it feels like the pc is reading wrong bits or have signal-timing errors.
It feels like the more activity the pc does at the same time the more the pc crashes. For example if I plug in a sound card the pc and cursor stutters when playing the windows startup sound and after the sound stops the pc runs fine again. Also the floppy drive could cause the pc to suddenly crash.
I dont know what could cause all of this issues.
Reply 9 of 18, by rasz_pl
majestyk wrote on 2026-08-04, 04:53:
rasz_pl wrote on 2026-06-09, 18:31:
I think this is the one:
https://theretroweb.com/motherboards/s/fic-mpi-4xx32
Yes, evasive added it a week after this post 😀 https://theretroweb.com/audit/App-Entity-Motherboard/23729
markpot4 wrote on 2026-08-03, 21:55:
good, so thats out of the way
some is not quantifiable. You should go over all
- SIMM socket pins
- U23 U24 VIA chipset chips
- cache sockets, test with no cache chips installed
- U40 video chip
- video ram chips
- U27 clock gen
- all the tht resistor networks
useless, tantalums either work of blow up
You didnt post picture of 'noise' here and cant see big images on that german forum without registering.
Im guessing the noise you are seeing is due to using modern LCD screen + weak factory VGA output filtering on mobo. This is normal, not sign of any defect. Back in the day CRT monitors had naturally limited BW and that noise was invisible, modern LCD samples analog video with fixed high clock and all this garbage shows up as noise and aliasing.
You didnt mention "What puzzled me most was the connection on the back" nor posted image of back of the pcb here. What is that wire? you can try putting something in between to pull it away from pcb, or wrap it in foil and connect that foil to ground.
Also post picture of rams you are using. Have you tried with different ram chips? Those symptoms also fit an EDO in a chipset not supporting EDO situation.
https://forum-classic--computing-de.translate … wapp#post626706
>Especially heavy loads, like when the sound card or the floppy drive is running, cause the PC to freeze or lead to multi-errors, even with the ISA card.
Those arent heavy loads, in fact those are the lightest loads possible. But they have in common DMA activity = something with cache coherency.
btw apparently VIA Venus is a 386 chipset. Could you please run cachechk (https://www.dosdays.co.uk/topics/mem_utilities.php) on it? Wonder how it looks compared to other 386/486 hubrid boards (with two or more sockets) questions..
Reply 10 of 18, by markpot4
My guess is some kind of ground bounce is happening on the board. Because the more activity the board does at the same time the worse it gets. Especially at the memtests at the part when it tests "low adress lines" you can see the activity as "graphical-noise" in the vga signal especially when a20, a21, a22 lines are in use. And I realized when two lines are active at the same time (for example a20+a21 the noise gets even worse)
Also I think the reason why the freezes are better with isa vga is bc there is less acitivity going on the mainboard when the onboard vga is off.
I also tried to disable l1 cache (that makes the
Noise even more visible). It changes the behaviour of the noise + freezes but didnt solve the problem.
I also have no l2 cache installed so this cant be a problem.
It also seems like the ground bounce sometimes changes the lows so that sometimes the cpu sees a 0 as a 1 and I think that cause the cpu to freeze. Also sometimes weird things happens before a freeze. One time at the bios self test it writes the text "floppy drive passed" 2 times instead of 1 time. And another time I type the command "dir" into dos it writes "¿dir" instead and freezes exactly at this time.
If it is ground bounce what could cause it and how can you fix that?
Btw there is also one tantal capacitor seems like its connected to nothing. All others are connected to gnd and +5V Vcc. But this one is only connected with gnd. It also have 0v all the time when the mainboard is running. All other ones have 5v. Does this mean a trace or the via could be broken? Unfortunately
it seems like 5v traces are not visible on the board bc they are on anoher layer inside the mainboard, same for the gnd layer.
Reply 11 of 18, by markpot4
Here are the results from the cache-mem test. 33mhz vs 50mhz.
Another thing I realized: the behaviour of freezes and noise changes when the mainboard is outside of the pc-case. Outside the board 40mhz cpu speed works more stable and 33mhz already freezes in bios most of the time and inside the case when the gnd is connected to the matal-case, the board however run better with 33mhz and freezes with 40mhz cpu speed on bios. So seems something is wrong with the gnd path or traces idk. I realized that the ground connections from the mainboard for the screws have a lot of scratches could this cause gnd-bounce or interference?
Reply 12 of 18, by rasz_pl
How about those pictures of bodge wires you mentioned on German forum? Its unlikely board has broken ground plane, its a solid pour internal to pcb, but its possible those bodges are for critical signals and are just laying too close to pcb.
Reply 13 of 18, by markpot4
Yes maybe that could be the issue. But I dont know how the mainboard developers dont recognise this freezing issue (it seems like they tested the board and put an ok sticker on everything). Maybe they dont test it long enough to trigger a freeze.
Btw I solved at least one issue: sound card issues happend bc scsi controller and 16bit audio shared the same dma. I didnt know that 16 bit use a diffrent dma channel than 8bit. After changing the dma fro 16bit the soundcard works fine. It also explains why the hdd data gets corrupted after I installed the sound card drivers.
Also I got the onboard graphic working fine with 20mhz or less bus speed (a dx2 with 40mhz and bus speed 20mhz works fine too). So some bus speed caused the issue not the cpu speed. With 20mhz bus speed it have no freezes and less graphical noice (but still visible). But its its strange that the onboard grahic cant handle more than 20mhz. I heard a lot of people saying they have similar issues when using 50mhz speed with freezes and timing issues. But 33mhz and 25mhz should normally work fine. And the stranges thing is that 50mhz works way better than 25mhz altought its a lot faster.
Also there are still some other unsolved mysteries other than the onboard freezes (but I think most of these dont have the same cause):
1. Floppy freezes especially when the pc is booting something from the floppy (also happend with isa vga card and changing the bus speed makes no diffrence here).
2. I realized another issue with the floppy: In dos the Floppy doesnt recognise when I put out a floppy and a new floppy is inside. When I type dir it reads the data from the old floppy and only a reboot helps that dos recognizes the new floppy.
In windows 95 i dont have this issues. This issue also happen with every floppy drive I tested.
3. The aspi driver didnt recognise the ide-cdrom drive. The cable and cd drive is fine it also is set to master bc no other device is on the ide connector but dos and windoes dont recognise it. Its a cd-rw drive from 2000s. Maybe its to new compatible with a 486 pc or too fast? The cable is also connected at the right side and the cd-rom drive rcieves power (It spinns and I can open and close it).
4. Sync problem: The Picture always go to the left or right when I start a game or the resolution is changed. This also happen with isa card too (maybe this is just a monitor problem). Sometimes plug in and out the vga cable helps.
Reply 14 of 18, by rasz_pl
floppy issue sounds like you might have wrong bios flashed. Windows ignores bios and talks to floppy directly (hsflop.pdr). You can confirm this loading windows in safe mode, afaik then it talks thru BIOS again.
Reply 15 of 18, by markpot4
I cant find any bios on the web. Think thats bc its an oem pc. But I think the bios is alright bc it said unisys 4253sx in the bios. And I see another one with this pc in a forum, having the same bios.
Also I still get Devide errors sometimes when launching an exe file (this also happens with isa vga). I also realized some weird keyboard/mouse timing errors in doom: when I move the mouse in doom first everything works fime but after 30 seconds the keyboard is doing weird things and pressing buttons by itself. This only happens only when a ps2 mouse is connected and only in doom not in other games.
Feels like this could also be some timing/signal issues.
I still think the whole mainboard have a lot of timing issues - Signals that come to late or to early or something. Maybe that was already an issue when the mainboard was launched. Its crazy that so many systems have problems:
Floppy, onboard graphics, keyboard timing issues when i use a mouse, devide erros
Maybe the via chipset that controls the whole board is bad 😒 Only things that are connected to the isa slots swems to working fine bc they are seperatet from the board.
Seems like the mainboard developers already tried to correct some signals by rerouting and bypassing traces on the mainboard. Idk if this is repairable bc nobody will know how signals are working on this board.
Reply 16 of 18, by MarmotaArmy
I doesn't hurt to check in bios DMA clock rate , i think It must be set to BUS/2. (or lower). I had a Unisys 486 with that option (not the same as yours)
I had some issues with a similar board regarding sound and networking and that fixed it.
Reply 17 of 18, by markpot4
Okay I find something out. The pc definitly have a power ripple problem on the mainboard at the 5v traces where the tantals are. The ripple happen at the exact time when the graphical-noise happen and when the pc is doing much memory-activity. I have got this ripple while doing the memtest with checkit. When the pc is doing not mich activity (for example being in dos) then the ripple is gone and the line is flat. Also I realized when I do graphical things there is no big ripple but the thickness of the line at the osci changes everytime I scroll through a menu or every time a graphic is loading (for example if the screen turns black bc it changes resolution the line gets thinner when the screen turns black and then thicker again when the graphic is loaded).
The question is does a tantal or ceramic- capacitor cause these kind of ripple or is it maybe any other broken thing on the mainboard? How can I found what cause this ripple?
Reply 18 of 18, by rasz_pl
LLM should be clever enough to tell you 40mV on 5V rail is fine
https://www.tomshardware.com/reviews/how-we-t … psu,4042-5.html "according to the ATX specification, are 120mV for the +12V and -12V rails, and 50mV for the remaining rails (5V, 3.3V, and 5VSB)."
caps are tehre to make the ripple smaller
your screenie shows the beating is at 32Khz, this is Video horizontal scan frequency, that sure looks like noise generated by graphisc and beats smaller when beam is retracing. You can try soldering couple 10-22 µF MLCC SMD capacitors near the graphic card on a 5V rail
but that ripple is in spec and shouldnt be the source of your problems. I still think it has something to do with bodge wires just laying close to other fast signals
