Quality of packet drivers: Intel
First post, by Grzyb
It's well-known that at least some of the packet drivers for 3Com PCI cards are buggy.
Now, let's try Intel...
NIC: Intel PRO/100 VE
CPU: Pentium III 800EB
HDD: WDC WD1200JB, running in ATA 100
software: FTP.EXE from mTCP Jan 10 2025, MTU 1500
drivers: see the attachment
all results in KB/s
native PD:
download to NUL: 8877
download to HDD: 193 !!!
NDIS+DIS_PKT:
download to NUL: 9042
download to HDD: 4321
ODI+ODIPKT:
download to HDD: 4264
So, when you encounter mysterious problems with some PD software, you know what to do...
And if you find a better PD for PRO/100 VE, let me know!
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 2 of 26, by Grzyb
Matth79 wrote on 2026-06-10, 17:13:
Not sure if the Seth Simon from here would be any better
Only marginally better...
download to HDD: 214
Reply 3 of 26, by MagefromAntares
Grzyb wrote on 2026-06-10, 15:29:
native PD:
While I haven't yet debugged the .com file, if there is a so large difference between downloading to NUL and to the HDD it usually means that there are no/little buffering of writes to the disk, which means that the HDD has to write each byte or small group of bytes separately, needing to seek the proper track and position again.
EDIT: If you wish to check if this is the issue, MS-DOS 6.22 comes with RAMDRIVE.SYS, allocate a disk in memory to try, if this is the case that will significantly increase the performance.
"A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it." - Dune
Reply 4 of 26, by Grzyb
Currently using the PD by Seth Simon.
Download to RAMdisk is fine - same speed as to NUL.
BTW: RAMDRIVE.SYS is limited to 32 MB - what's the recommended replacement?
And why does "ramdrive.sys /e" in MS-DOS 7.10 require "device=c:\windows\himem.sys" in CONFIG.SYS? In this DOS, HIMEM.SYS is loaded automatically!
Reply 6 of 26, by Grzyb
Joseph_Joestar wrote on 2026-06-11, 10:59:
Try XMSDSK.
Thanks, seems to work fine!
Meanwhile, testing with another client - FTP2P...
download to RAMdisk: 11224
download to HDD: 217
Reply 7 of 26, by wierd_w
Unrelated to packet driver testing, but just random trivia:
Xmsdsk hosted ramdisks can be used with the drvspace driver. You just need to have the drvspace.000 file present on the ramdisk, then point scandisk at it with the undocumented /mount argument. Scandisk will mount it for you silently.
1gb is the max officially supported size though.
if you have 64kb of upper memory to just blow (drvspace.sys /move in config.sys will relocate it to umb instead of dos memory), it can be useful. A whole volume can be ftp'd then mounted this way.
Derail over--
Carry on!
Reply 8 of 26, by EduBat
I had problems with ne2000 packet drivers on my 486, which disappeared when I disabled both the processor and the external caches. It's weird, I don't know why it worked...
Reply 9 of 26, by MagefromAntares
Grzyb wrote on 2026-06-11, 12:49:
Thanks, seems to work fine! […]
Try XMSDSK.
Hmm it seems that FTP2P is another client that doesn't do proper buffering of data before writing to disk.
As an alternative to RAMDRIVE.SYS or XMSDSK you might also try it with SMARTDRV with write-behind cache enabled: SMARTDRV <drive letter>+ <other parameters...>
The "+" after the drive letter tells SMARTDRV to enable write-behind caching of the given drive, so unless if the given client bypasses DOS File Write interrupts/functions it will be cached by SMARTDRV instead of directly written to the disk, it also has the advantage that you don't have to copy the file from the RAM disk to permanent storage after transfer, however there is a big disadvantage to this method, whenever shutting down the machine you need to run SMARTDRV /C to make sure that the caches are flushed so data doesn't get stuck half written(And crashes are also more likely to result in lost data).
Reply 10 of 26, by Grzyb
Using the PD by Seth Simon, and mTCP FTP...
smartdrv c+
download to HDD: 286
Seriously, can't suspect the FTP clients - both work fine with both NDIS and ODI, even without SMARTDRV.
There's something wrong with the Packet Drivers, but I can't even imagine what exactly...
Reply 11 of 26, by Grzyb
download to HDD:
mTCP Jan 10 2025 FTP: 214 KB/s
FTP2P 3.5: 219 KB/s
FTP4DOS 0.9.5a: 3.1 MB/s !!!
All three are based on the same TCP/IP stack, right?
There's some extra buffering in FTP4DOS, or what?
Reply 12 of 26, by mbbrutman
Can you send a trace of the slow download? There is probably a clue in the trace.
Reply 13 of 26, by Grzyb
mbbrutman wrote on 2026-06-27, 15:58:
Oh dear, with DEBUGGING=127, the logfile quickly grows HUGE...
Reply 14 of 26, by mbbrutman
What FTP_TCP_BUFFER and FTP_FILE_BUFFER sizes are you using? (If you are not setting them explicitly in the mTCP configuration file then you are getting 8KB for each setting.
The mTCP client buffers file writes, but now that I look at the code there is a case where performance might be bad and it is when both of those buffer sizes are the same. If you increase FTP_TCP_BUFFER to 16384 it should work much better.
This new client is setting that to 16384, but it's only writing 4KB to disk at a time. If I've read things correctly, after you make the change the mTCP client might even be slightly faster.
Reply 15 of 26, by Grzyb
mbbrutman wrote on 2026-06-28, 01:23:
Everything was default, except for MTU 1500.
Adding FTP_TCP_BUFFER 16384 :
mTCP Jan 10 2025 FTP: 534 KB/s
FTP2P 3.5: 577 KB/s
FTP4DOS 0.9.5a: 3.0 MB/s
Reply 16 of 26, by mbbrutman
Grzyb wrote on 2026-06-28, 08:42:
Everything was default, except for MTU 1500. […]
FTP2P 3.5: 577 KB/s
Okay so now try setting the file buffer size to be 4K to match the other program and see what that does.
The way it's behaving it looks very much to be a flow control issue and it depends on the speed of the writes and when they are done.
Reply 17 of 26, by Grzyb
Adding FTP_FILE_BUFFER 4096 :
mTCP Jan 10 2025 FTP: 486 KB/s
FTP2P 3.5: 473 KB/s
FTP4DOS 0.9.5a: 3.2 MB/s
Reply 18 of 26, by mbbrutman
I'm pretty sure it's a flow control issue because there's no magic that allows a GUI interface to make that kind of difference.
Just try some variations and see what you get. I have one idea that might make a difference for everybody and I can post test code when I get some free time if you're interested in trying it.
Reply 19 of 26, by Grzyb
OK, I hope to do more experiments soon...
Meanwhile, I've tried running FTP.EXE with a response file:
anonymous
password
cd directory
get testfile
bye
ftp 192.168.169.170 < filename.rsp > filename.log
Works fine, so I can easily automate benchmarking, and do a full matrix of multiple variables.
TUI/GUI are nice, but never underestimate the power of CLI!
