First post, by kotel
- Oldbie
Hi
So I pulled this card out of my storage to play around and after installing drivers for it and running the default 3dmark00 tests, it just freezes the entire PC right at the start of test 1 (the one with the helicopter).
What I tried so far:
Different driver versions (71.84, 45.84, 5.31)
Cleaning the edge connector
Running MATS 3.41 on it, which reported that end memory location (04200000) is greater than top of RAM (02000000), forcing it to test 32MB max passes with no errors
Trying different boards (same issue)
Trying it under 2k (for the life of me I can't get 3dmark to detect dx9 correctly so it just errors out saying I need to have dx7 or above, with a good card it works fine)
Trying it under XP where it works perfectly fine
Trying a different BIOS for the tnt2 m64
I have no idea for such weird behavior, why does it only work under xp with 3dmark00 and 01SE, but it doesn't on 98 with 3dmark00? It works fine under 3dmark99 tho.
I tried another tnt2m64 which doesn't have these issues and it just works.
Any ideas?
Always has the weirdest issues happen, and always is all alone with them
