First post, by Grimoz
Hi all,
I picked up a Sparkle Geforce3 Ti 200 for my current build but its in need of some repairs, one of the Toroidal Inductors has been knocked off and i have absolutely no idea how to identify what type i need to get to replace it with. Ive attached a photo below and if anyone can help out it would be much appreciated. Thanks in advance
The attachment IMG_8806.jpeg is no longer available
Reply 1 of 3, by tehsiggi
It has an alternate footprint for a SMD conductor - if you look for pictures of it in the web, you'll find the variant with the SMD inductor:
The attachment ti300.png is no longer available
It's marking UP2B 100 - which leads to: https://mou.sr/43tgS8C
Eaton UP2B-100-R
Tolerance: 20%
Max DC current: 4.3A
Max DC resistance: 26.7 mOhms
Saturation current: 3.3A
You can use either the exact inductor or any one that fits the parameters. Hope that helps.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 2 of 3, by Grimoz
tehsiggi wrote on 2026-06-12, 19:02:
It has an alternate footprint for a SMD conductor - if you look for pictures of it in the web, you'll find the variant with the […]
Eaton UP2B-100-R
Tolerance: 20%
Thankyou, really appreciate the help, do you think its worth changing both inductors due to the age of the card?
Reply 3 of 3, by tehsiggi
Grimoz wrote on 2026-06-12, 21:33:
Eaton UP2B-100-R
Tolerance: 20%
Only if you are into esthetics. Usually inductors don't really age.
