First post, by sparki
Does an lvd scsi bus *require* a twisted pair cable? I've found a regular ribbon cable with an lvd terminator and it seems to negotiate and run fine. It's connected to an adaptec 2940u2w so it's a 80 mb/s bus and there's only 1 drive so i'm probably not stressing the bus too much. Should i keep running the bus in lvd or should i force it to SE?
