First post, by hwh
There have been a number of glue topics. Most are about ABS. This one may be different.
Project is my old 1GB USB drive. I pried it open (note to self, use blow dryer next time) to get it repaired. Now it's in pieces. I don't want to use super glue because of how it causes the frosting mess on transparent plastic. The case is transparent. Also, I'm not really trying to weld it together. Together, yes. But not beyond being pried open again if need be. So it has to be clear and not super glue. Right now my choices are super glue and wood glue. Not really helpful.
I wonder what was originally used, since these pieces were glued together from the factory.
Also, little complication, the glue channel is extremely narrow, I can't exactly get globs of glue around here. Open to suggestions.
