Disruptor wrote on 2026-06-18, 07:15:
I have following ideas:
- Try another IRQ
Think I've tried all IRQ's, and with all of them now get the following:
- Insufficent memory to start Windows. Quit one or more memory resident programs, or remove unnecessary lines in Autoexec.bat or Config.sys.
- Windows protection error. You need to restart your computer.
- Self restart upon finishing loading Windows.
Tried clearing up Autoexec and Config to the level Autoexec is two lines, still refusing to load. Soundblaster moved to IRQ 10.
Fail-safe DOS Prompt:
Bad Command.com. Enter the path for Command.com and press Enter (until a hard restart, then it works again).
DOS diagnostics: All tests OK, or Interrupt Test failure, depending on IRQ.
Disruptor wrote on 2026-06-18, 07:15:- Is there a possibility to change the media type?
Media type? 😮
dionb wrote on 2026-06-18, 07:58:
Normally you wouldn't see link at the other end if Rx was borked.
What OS are you using and what kind of driver? There's a DOS packet driver for these which is really basic. If you're not already using it, try that with mTCP.
Win95B, no additional driver. Windows identifies the card as NE2000 compatible.
Yoghoo wrote on 2026-06-18, 08:06:
What routers did you test it on? Do they support 10Mbps network connections?
Had the same issue some time ago with some newer switches which don't support 10Mbps network cards anymore. So used a dedicated 10/100 switch for my retro hardware instead.
Mainly Asus N56U, which worked with a slightly later UMC UM9008 in Win 3.11.
Also a Tilgin Vood 342 and a D-Link DE-809TC (proper BNC capable stuff! 😁) but only in first release Win95.
Project 357575: ECS U4914-G | i486DX2-66 | ET4000/W32 | CT3900
Main: IBM PC300PL | PIII 750 | Viper AGP + V2 SLi | CT4500
