Socket 370 - Aiming For The Stars
First post, by PcBytes
Inspired by supercordo's Netburst and 462 threads, I figured I would go ahead and do one for Socket 370 as well.
Mandatory:
- results must include the following - 3DMark scores, CPU-Z, and GPU-Z (*1)
- Intel Socket 370 only. Slotkets and Socket converters (e.g Socket 370 to Socket 8, like the Powerleap PL-ProII) are accepted as well, original Slot 1 models are not. As long as it uses a Intel 370 chip, it qualifies.
- Unfortunately no VIA/Cyrix chips for this thread. There is an existing "Aiming For The Stars" thread for VIA C3 , made by Jasin Natael, and it seems active. (last post is a few days ago.).
- no chipset restrictions. Go WILD!
- no GPU restrictions
- no OS restrictions
- no LN2/sub-zero solutions allowed. Air and watercooling is accepted, as well as using ice as watercooling.
- NO STOCK SCORES! That's what "Aiming For The Stars" is about! Squeezing the absolute juice outta yer chips.
- 3DMark 99 - https://benchmarks.ul.com/legacy-benchmarks
- 3DMark 2000 - https://benchmarks.ul.com/legacy-benchmarks
- 3DMark 2001SE - https://benchmarks.ul.com/legacy-benchmarks
- CPUMark 99 https://thandor.net/benchmark/4
Scores will be divided into each core category - Mendocino, Coppermine, Tualatin. The type of 370 CPU will be mentioned - Celeron or Pentium III, as well whether it's a slotket, socket adapter or plain 370.
Socket 370 - 3DMark 2001SE scores:
Tualatin
1. Standard Def Steve @ 14059, 1628MHz, 155FSB, 6800GT, VIA Apollo 266T
2. shevalier @ 9792, 1275MHz, 150FSB, R9800XT, i815E
3. Repo Man11 @ 9712, 1372MHz, 144FSB, X800Pro, VIA 694X
Coppermine
1. Repo Man11 @ 8238, 1080MHz, 144FSB, X800Pro, VIA PM133
2.
3.
Mendocino
1.
2.
3.
Socket 370 - 3DMark 2000 scores:
Tualatin
1. Standard Def Steve @ 12132, 1628MHz, 155FSB, 6800GT, VIA Apollo 266T
2.Repo Man11 @ 9849, 1372MHz, 144FSB, Ti4600, VIA 694X
3.
Coppermine
1.Repo Man 11 @8263, 1080MHz, 144FSB, Ti4600, VIA PM133
2.
3.
Mendocino
1.
2.
3.
Socket 370 - 3DMark 99 scores:
Tualatin
1.Repo Man 11 @ 10892, 1372MHz, 144FSB, VIA 694X
2.
3.
Coppermine
1.
2.
3.
Mendocino
1.melbar @ 1291, 513MHz, 68FSB, Rage Pro Turbo 2x (onboard), i440LX
2.
3.
Socket 370 - CPUMark scores:
Tualatin
1.Repo Man 11 @ 122, 1372MHz, 144FSB, VIA 694X
2.
3.
Coppermine
1.Repo Man 11 @ 93.9, 1080MHz, 144FSB, VIA PM133
2.
3.
Mendocino
1. melbar @ 36.6, 513MHz, 68FSB, i440LX
2.
3.
*1 - In case you cannot run GPU-Z, HWINFO or Everest Home Edition can be used for the GPU information, as long as they don't block the CPU-Z and 3DMark score view. This applies for 9x mostly, as IIRC there aren't 9x-compatible versions of GPU-Z.
Reply 1 of 58, by marxveix
There are some non Intel Socket 370 CPU-s, like VIA Cyrix III / VIA C3
https://en.wikipedia.org/wiki/Cyrix_III
https://en.wikipedia.org/wiki/List_of_VIA_C3_microprocessors
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 2 of 58, by PcBytes
marxveix wrote on 2026-06-18, 11:47:
I did mention that it's only for Intel CPUs, as there already exists a separate C3 Aiming For The Stars thread (linked in the original post, although it's in the Video section, of all places).
Reply 3 of 58, by supercordo
Hell yeah!!!!!!! Ill come play once im down with Socket A. Itll be nice not having to keep score this time.
Reply 4 of 58, by paradigital
Time to drag out the PL-iP3/t.
Reply 5 of 58, by melbar
3Dmark 99 for my s370 SFF build. (not shown in Marvin's system specs yet ...)
My Celeron 500 (tiny OC @ 513 Mhz with FSB 68MHz).
Onboard Ati Rage Pro Turbo AGP 2x.
For 3Dmark2000, it's just too slow...
The attachment 3dmark99.jpg is no longer available
The attachment 3dmark99_2.jpg is no longer available
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 7 of 58, by shevalier
Until someone comes along with a TUSL2-C fitted with an overclocked Pentium 3S processor (1.4 GHz) running at a bus speed of 166+ MHz.
Or a similar motherboard from Abit.
I’ll stick with my AOpen MX3S for now. Unfortunately, it supports the frequency combinations 133/133, 150/150 and 166/125 (this motherboard does not support 166/166)
Re: Rebuilt W98 PC (P3 1.4 GhZ)
3DM2001SE - 9792
file.php?id=164400&mode=view
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 8 of 58, by PcBytes
Added to the scoreboard.
I have my ST6 that runs a 1.13 @ 186FSB that I intended posting last night but, for whatever reason the 7600GS I picked up recently seems to not be 100% stable, so I will postpone it until I get hold of a X1950Pro I ordered recently. I also have a 7800GS however it acts the same as 7600GS, which leads me to believe it's either a driver issue or some sensibility between the OC, the late HSI-bridged nVidias and the i815EP chipset, since I rememeber I could finish runs with a Rialto'd X800GTO and a native X850.
What I can say about the ST6 and 1.13 Tually I have though, is the 186FSB is its absolute stable limit. I've done everything possible to push it close to 190, but 186-188ish is its utmost limit. Either core or the MB are at their limit but I couldn't get another S type Tualatin to test.
I might pick up a SA6R for Coppers down the road though - someone sells one that is in need of a recap with a 1GHz P3 and it seems tempting.
(edited as I misremembered the max FSB I got my 1.13 at. I always thought it was 189 yet I recall 3DMark wouldn't finish at that, or anything past 188.)
Reply 9 of 58, by shevalier
PcBytes wrote on 2026-06-21, 05:38:
I have my ST6
Clock IC RTM560-25 -"up to 250MHz"
Yes, with a this Clock IC like that on the motherboard, you can achieve high results.
Reply 10 of 58, by melbar
Here the missing CPUmark99 value from my little celeron...
The attachment CPUmark99.jpg is no longer available
Reply 11 of 58, by H3nrik V!
Love that slotketed s370 cpus are allowed but not native slot 1. That means a Celeron 300A in slotket is fine but not an SL32A 🤣
Anyways. Considering my weapon. Probably it's an excuse to see if my TUSL2-C actually works 🤔
Reply 12 of 58, by PcBytes
H3nrik V! wrote on 2026-06-25, 21:34:
I have plans for a native CPU Slot1 competition in the future as well, which is why that rule exists.
Reply 13 of 58, by H3nrik V!
PcBytes wrote on 2026-06-25, 22:14:
Oh, makes perfect sense, then 👍
Reply 14 of 58, by BoYan
oh, I would so like to participate in this one as I have 3 interesting machines to run, to make everyone go crazy 😁
- Abit BP6 with 2 366s at 535-550MHz and a lot of RAM (768MB)
- Chaintech 6VIA5T with Tualeron 1.2GHZ and
- IBM x232 eServer with dual P3S 1.4GHz and only a PCI slot, which could take a Nvidia GT520/GT610
..but I need to dig all up from my storage - my favourite era of retro gaming 😁
Reply 15 of 58, by Repo Man11
I gave it my best with what I have. Soyo 7VTA-B, a 1000 Coppermine, and a couple of different video cards. My best 3D 2001 score was with the X800, but my Ti 4600 scored slightly higher on 99 and 2000. The overclocking options are limited - the next higher setting for the FSB is 155 but at that speed it will blue screen Windows 2000 no matter what I set the voltage to.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 16 of 58, by Repo Man11
Next up: a Tualatin 1266 (one with an adapter) in a Tyan S1854. I had some issues getting this going and the cure was odd. I have two of these boards - one has no onboard sound and an ISA slot, the other has a Creative sound chip and no ISA slot. I had tried this Tualatin in both boards and it worked fine, but when I had it in the one with onboard sound it would restart just as it was finishing up installing Windows 2000 and XP. I thought maybe it was because the BIOS didn't fully recognize it, so I ran the BIOS Patcher, and now the CPU is recognized but the problem remained. I disabled the onboard sound, and it worked fine? I then put in a Coppermine 650, and it worked fine with the onboard sound but it would not make it to the desktop with the Tualatin and the onboard sound enabled. I realized that I hadn't had this issue before because the other board doesn't have it, and when I used it in this board prior to this I had a sound card installed. So I again disabled the onboard sound and installed a Creative CT4670.
Sadly, this Tyan board has no overclocking options so I had to resort to using CPUFSB; luckily, the stock core voltage allows it to hit 1,372 MHz. The next jump is from 144 to 150 FSB and that's too much for it.
Reply 17 of 58, by Repo Man11
That is the first time I've ever successfully used a bit software to overclock the FSB. I've had bad luck in that the times before the clock chip wasn't included or it couldn't be accessed by software, but it worked like a charm this time.
Reply 18 of 58, by Repo Man11
Same as before, the highest 3d 2000 score is with the Ti 4600.
Worth mentioning is the memory, Kingston KVR133X64C3 - the 512 meg stick I have handles 144 MHz with tight timings (though CAS 3) at default voltage. Most of the generic PC133 I have falls short of this.
Interestingly I installed Win98 on the same hardware and the 3D 99 and 2001 scores were notably lower, but the 3D 2000 score was almost identical. Same video driver (45.23) slightly different Via drivers ( 4.35 for Win 98 4.43 for 2000). Not the result I was expecting.
Reply 19 of 58, by shevalier
Repo Man11 wrote on 2026-07-05, 17:26:
RAM chips from Hynix?
In my opinion, their PC133 chips aren't good for overclocking.
To be successful, you need a motherboard that supports 166/166 (FSB/RAM) and memory that can run 5-2-2-2 at that frequency.
With high-end Pentium 3 processors, increasing the core frequency no longer yields significant gains; the FSB becomes the limiting factor.
This is likely why 1.4–1.5 GHz is the official limit for these cores.
