First post, by Nexxen
Hi all!
I was setting up a MS-DOS only machine.
1st mobo:
https://theretroweb.com/motherboards/s/msi-ms-6163-v1.0-bx13
Upgrade bios from 2.1 to 2.7: from clean screen to Post like in pics n.1 and 2.
2nd mobo: https://theretroweb.com/motherboards/s/lucky- … -6abx2v-ver-1-2
Same results.
3rd mobo: https://theretroweb.com/motherboards/s/soyo-sy-5ema-plus
Same as above.
I swapped RAM, CPUs, Drives... no change.
I tried a few video cards, nVidia 200MX, 440MX, Rage, S3, TNT... TNT2 M64 is the only one with crystal clear image (even has a 470µF bulging a bit 😀
This is a curiosity as there are incompatibilities but I'm wondering if there is a list somewhere with compatibility advice per Chipset.
I never had this before.
I used Phil's Dos pack, games have requirements such as EMS, XMS or Conventional only - this is not the issue.
Thanks for any input, as always.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 1 of 5, by keropi
at least for the 1st problem with the bad font on the setup program you can use this: https://www.bttr-software.de/products/fix8x14/
to add back the missing font support
the rest look like dram issues to me
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 2 of 5, by Nexxen
keropi wrote on 2026-06-19, 19:47:
Uncanny, exact same pics 😀
Thanks mate!
Now I have to go check ram on all my cards.
Can't say if I love you giving me a new side quest or hate you... It's probably for the best to check 'em all.
Reply 3 of 5, by keropi
Nexxen wrote on 2026-06-19, 19:56:
Uncanny, exact same pics :) Thanks mate! […]
Thanks mate!
Can't say if I move you giving me a new side quest or hate you... It's probably for the best to check 'am all.
hahahha
well to check vram you can use x-vesa: Re: [Release] X-VESA 2.0 Public Beta – Deep VESA diagnostics for real DOS hardware
you do not need to have a vbe2.0 bios, even vbe1x will work for this
Reply 4 of 5, by Nexxen
keropi wrote on 2026-06-19, 20:01:
hahahha well to check vram you can use x-vesa: Re: [Release] X-VESA 2.0 Public Beta – Deep VESA diagnostics for real DOS hardwar […]
Thanks mate!
hahahha
I tried necroware's and there are bad chips 🙁
Soldering now, with 30+°C is NO. Adding items to queue for my usual autumn/winter soldering frenzy.
Thanks for the suggestion. I'll try the other program as well, welcomed addition to the library.
Reply 5 of 5, by Nexxen
Guess what, using a DOS installed via the 3 disks set = no issues with Simcity.
Using Phil's DOS Boot Disk Easy and Fast, https://www.philscomputerlab.com/dos-boot-dis … -easy-fast.html, I get the errors in Simcity.
Guess he forgot to add something.
