First post, by 88mphTim
I have a PB500 that still currently works, but I know I need to remove the battery. Just curious (as systems I have done this to before were not this old, etc), can i literally just clip it off? Or do I need to solder a wire to it, replace it with another? I am happy to run without a battery if it will run without one. I just don't know if the system will even run without (I just got an IBM PS/2 running and obviously it needs a battery).
