I have run into a few systems which only supported one floppy drive in hardware, the select for the second drive was not brought out (perhaps saving a pin "that nobody ever uses" on an IC)
Assuming you have a proper "twisted" cable supporting A: and B: - Boot DOS on the working drive, and try accessing the second with ImageDisk.
IMD does not use BIOS - accesses the floppy hardware directly (I have both drives set to "NONE" on my IMD system - to avoid anything else trying to "mess" with the floppies).
This will tell you if the second floppy hardware is connected and working.
Also, since it doesn't use BIOS - IMD can easily use differnt drives connected though the same floppy interface as well. I do this to support many different drive types directly (5.25" - 360k 1.2m, 3.5" - 720k 1.44m, 8") - I just have a "power switch box" which cuts all power lines to a drive while I change it.
but ... for "normal" use, BIOS has to be configured for the correct drive type. There may be a tool somewhere to "restore" BIOS on the fly - but I've never really looked .
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
