First post, by retrosprite440
I setup Commander Keen 4-6 recently (I'm using Dosbox-X) and am trying to adjust the music volume independently, if there is a way. It's very low compared to the sfx. The music and sfx both have the Adlib/Soundblaster option checked and I've read that the music uses the Adlib and the sfx uses Soundblaster. Is this correct? Either way, I've tried to make adjustments to both the SB and FM independently through Dosbox-X's "mixer" utility. The sound mixer panel shows that the channels are being boosted, but I get no actual volume boost. The only time I get an actual volume boost is when I make adjustments to the master channel. Can I actually adjust the music volume independently for these 3 games? And am I correct in trying to adjust the FM channel for the music specifically?
