First post, by retrosprite440
I'm new to VirtualMidiSynth. I downloaded it recently primarily to send midi out from ECWolf according to a tutorial I came across. But I'm realizing that many other programs run VirtualMidiSynth upon opening. I know how to prevent a program from running VirtualMidiSynth via the blacklist function. I've already done that with other programs. However with Dosbox-X, I'm curious if there's a way to block it from within Dosbox's config file, because I don't know whether or not there's a future scenario where I would want to try to use it with Dosbox.
And part of this post is me also asking what options exist within the Dosbox-X/VirtualMidiSynth combination? The deepest I've gone so far with MIDI in Dosbox is setting up MUNT. I don't know the extent of the possibilities with VirtualMidiSynth.
