First post, by JAKra85
Hi,
I have troubles getting my PS\2 optical mouse to work on this motherboard:
https://theretroweb.com/motherboards/s/bek-tronic-bek-p405
Mouse pin on MB:
I've measured the GND pin. 3 to go...
The other 3 pins all show 5V on the multimeter, however I narrowed down the Vcc pin by try and test method.
With the mouse connected to GND and "presumed" Vcc only: the optics are on.
Based on this I think I have this PIN layout:
Mouse connected based on this layout and mouse still not working...
Tried swapping Clock and Data pins, same.
Worth to mention:
On this motherboard there is no "external" keyboard BIOS.
The keyboard BIOS socket is there.
Also, there is this JP12 jumper setting:
(If I close this, the system won't boot.)
1)
Could it be that the MB has integrated (ALi chipset) Keyboard but not PS/2?
2)
I am trying to get a Keyboard BIOS and try again with the JP12 closed.
Any feedback or ideas are welcomed! 😀
Thanks!
Kind Regards,
Attila
Retro PC Gallery:
https://docs.google.com/document/d/1ara32t4rV … nU/edit?tab=t.0
