First post, by Nexxen
Hi all!
I have a few of these and I could never test them as I don't have a suitable board for that.
Is there any affordable project out there I could buy for this purpose?
Soldering isn't an issue.
I know one such project but it's big and comes with buying 5 boards + parts and it's quite costly in the end.
I don't have a clear idea, don't mind explaining things.
Thanks for any advice.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 1 of 8, by the3dfxdude
Are you going to keep them, or sell them?
Reply 2 of 8, by Nexxen
the3dfxdude wrote on 2026-07-01, 12:48:
Keep.
I also have a V20.
I'll prolly post the same for Zilogs.
Reply 3 of 8, by the3dfxdude
So if you are looking for a project, there is Sergey's Kiselev's Micro 8088. As it is a CPU on an expansion slot board, you need a few more boards to make a complete system. But this project is a little better for hobbiest work rather than the more recent, elaborate projects.
For 8086, the support ICs are different enough that it would be a different project. I am not aware of a current 8086 project.
If you aren't looking for a hobbiest project, then it's just a matter of finding two mother boards that use those chips to test them.
Reply 4 of 8, by Jo22
I know of this project here, it's about interfacing an 8088/V20 or 8086/V30 to a Raspberry Pi.
https://www.homebrew8088.com/home/archived-pa … es/raspberry-pi
Edit: https://www.homebrew8088.com/home/raspberry-p … -second-project
Reply 5 of 8, by Nexxen
Jo22 wrote on 2026-07-01, 16:23:
Too difficult for me. I'd have to buy a Pi and all the rest.
But it's a nice read, maybe I'll learn something. 😀
the3dfxdude wrote on 2026-07-01, 13:59:
Yeah, it requires other boards.
People have evolved to the "I'll create it if does not exist" state. Very nice porjects.
I'll wait for more answers, hoping for a a simpler solution (yes, I'm lazy on this one - sorry).
I found an Amiga board with a 6-pin power connector and a 8088.
It has 3 x 8-bit slots. If nothing comes up I can always buy that one. They ask 50€.
Reply 6 of 8, by the3dfxdude
Are you looking at PC/XT compatible or more of a trainer or simple controller board? Even if you build something around the 8088, there is still alot of logic and support ICs you need. I don't think it will get much simpler if you strip away PC architecture. But I think I can find a drawing out of a textbook for the 8088 that can be used for experiments to show something simple that the CPU works.
Reply 7 of 8, by Nexxen
https://theretroweb.com/motherboards/s/commodore-pc-10-iii
Could this fit the bill?
Reply 8 of 8, by Nexxen
IBM 5160 or similar replica is available?
