First post, by Retro-o
Evening folks,
System:
Socket 7: AMD K6-2 266MHz
128Mb PC133 DIMM
Graphics: S3 Virge DX/GX 4Mb RAM
Sound: AWE 64
O/S: Win98SE
New Motherboard: Octek Rhino 12 - https://theretroweb.com/motherboard/manual/oc … 78046669897.pdf
I purchased this motherboard recently as my previous one had died. The motherboard was confirmed as working and the seller provided photos of the boot sequence. After setting everything up and powering on nothing happens.
PSU powers on and fan runs. Green power l.e.d lights up. That's about it. No hard drive activity and the monitor doesn't receive a signal to turn on.
I'm wondering if the CPU is the issue here as the board only supports up to K6/233.
I set the 'CPU Type'' jumpers to AMD K6/233:
JBF-1: 2-3
JBF-2: 2-3
JBF-1: OPEN
JCK-5: 2-3
JCK-6: 1-2
JCK-7 2-3
I set the 'CPU core voltage to 2.2V which from what I've read is the recommended value for the K6-2 CPU
JP1- 5-6
JCK1/2/3 - 1-2
CPC Clock Setting is set to 66Mhz
I've double checked the clock battery, it's fine and displaying the correct voltage. I also tried removing the memory to see if I would get a beep from the speaker, but nothing. I've double checked the speaker connection and it's correct. The speaker worked fine when the old board was plugged in and would beep when the memory wasn't present.
Am I missing something obvious here? Any help or advice would be greatly appreciated.
Regards
Col.
