First post, by itzCrassio
Apparently Soltek motherboards have bad capacitors. Somehow still boots up.
Reply 1 of 5, by PD2JK
If only that goo had been purple too...
Good luck fixing them caps, looks like a board with RoHS solder, doable but needs a bit more effort.
has all kinds of stuff
Reply 3 of 5, by itzCrassio
it does somehow work
The attachment 20260703_130006.jpg is no longer available
Reply 4 of 5, by wierd_w
It will be crashy and unstable, and is likely running out of voltage spec.
Replace the caps.
Reply 5 of 5, by cyclone3d
PD2JK wrote on 2026-07-03, 09:56:
Helps to add lead bearing solder to the current trash solder.
Makes it melt a whole lot easier.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
