First post, by hekliet
I used to grind Princess Maker 2 a lot some time ago when I was obsessed with it. Today, I felt an urge to install it in DOSBox again, but instead of grinding, I started editing my savefile. I figured out where all the stats are located, and then wrote this script to do the patching. You can patch your saves selectively and with the values of your choosing by editing the script, it's really self-explanatory. It should make exploring different endings easier, if you don't mind the cheating.
Homepage: https://hekliet.nekoweb.org/pboost/
Github: https://github.com/hekliet/princess-booster/
