First post, by ZilogZ80
Hi folks,
I am pulling my hair out over a Sapphire Radeon X1950 PRO 512 MB AGP and Shuttle FB61 V3 (sb61g2 v3) combo. The system posts to a black screen and the CPU fans spin at full speed. Other AGP cards work fine in the Shuttle and I've replaced the PSU. I've done basic troubleshooting like changing AGP aperture as well. The Shuttle BIOS doesn't expose AGP Fast Writes, sideband addressing, or AGP 4/8 so I can't troubleshoot further without modding the BIOS.
I don't think the Rialto Bridge is dead either as the card works fine on my other PC. Given the post sequence fails so early I'm wondering if it occurs during AGP initialization before the VGA Option ROM is even executed.
Has anyone seen a similar issue on an Award BIOS like this? The X1950 Pro AGP seems to have been well tested on other 865G motherboards so I'm curious if the Rialto is being temperamental over a overall chipset limitation.
Best regards
https://global.shuttle.com/products/productsD … 20V3&c=xpc-cube
https://www.techpowerup.com/gpu-specs/sapphir … x1950-pro.b7825
