Owarix. 2026 (DOS)
First post, by orac81
OWARIX is a new open source small game for MSDOS, Commodore 64, Vic20 (Unexpanded), Plus4/C16, PET40/80, ZX Spectrum and Windows/Linux via SDL. The Vic20 version is just 3K.
Download:
https://github.com/orac81/miniapples/raw/refs … -bin-latest.zip
Source:
https://github.com/orac81/miniapples/raw/refs … arix-latest.zip
The attachment owarix-c64-1.png is no longer available
Owarix is a version of one of the oldest known two player games, Oware or Mancala. Boards dating back to Ancient Egypt and Rome have been found, and some finds possibly date the game back as far as 6000 BC.
Commands:
1-6 - Choose pit to move.
N - Start a new game.
Y - Change no of pits.
U - Change no of stones in each pit.
G - Make computer take turn, swapping sides.
A - Auto play demo, Computer v Computer.
I - Change computer IQ, depth of search.
T - Toggle 2 player mode, human v human.
V - Toggle simpler/faster display.
H - Display help.
ESC - Quit to OS (if there is one).
(For a simple quick demo, hit A for Autoplay.)
The attachment owarix-pet.png is no longer available
HOW TO PLAY
The board has 6 small pits on each side; and a large Master pit at each end. Your master pit is on your right, the stones in that are your score. To start four stones are put in each small pit. When it is your move, the player picks up the stones in a pit (1-6) then, moving counter-clockwise, drops a stone in each pit in turn (but skipping the opponents master pit).
If the last stone lands in an empty pit owned by the player, and the opposite pit contains stones, both pits are captured and placed in the players master pit. If the last stone lands in the players master pit, the player moves again. When a player has no stones in their small pits, the game ends. All players stones are added to their master pit, and the player with the most stones wins.
In this version of the game "Side A" (human) plays the bottom pits, with the Master pit to the right, and the Computer plays the top pits. You type a number 1-6 to choose a pit. Remember, if your last stone lands in your Master pit, you get another move!
The attachment owarix-v20.png is no longer available
NOTES
The IQ search level is normally restricted to the range 1-9, wrapping back to 1 when you go past 9.
This is the number of moves the computer looks ahead. To search deeper, you can set 2 player mode then the IQ can be set as high as you want.
But searches can become very slow when you do this, which is why it is normally restricted. On 8 bit platforms levels above 5 will be slow.
A few features are missing from the 3K Unexpanded Vic20 version, ie: the Help screen is not available, and the Board width is limited.
SOURCE CODE NOTES
Owarix uses the classic Alpha-Beta recursive search algorithm. If the move list is sorted before search, you will get even deeper/faster searches, but that requires more storage and code, I wanted to keep it small so that it builds on a 5k VIC20. Even with this simple algorithm, it can beat most casual players.
Owarix is a working example for the "Very Tiny Development Layer" (VTDL) portable library. This is a library specifically designed to be efficient
with very small target systems, for example it can target an unexpanded 5K VIC20.
Note that a console version can be built by setting: #define USE_C99 1
For more details, see "vtdl.txt" in the tdl folder.
The attachment owarix-zx.png is no longer available
https://orac81.itch.io/
Reply 1 of 2, by konc
Always nice to see stuff developed for the less popular and the less capable home computers, and your list is impressive!
Reply 2 of 2, by zyzzle
Very neat. Thanks for releasing it and porting to so many old systems. This is the type of stuff I live for. Great little self-contained programs and games like yours.
