XMPlay Extended version
First post, by Roland User
Hi )
If you use Windows XP and newer , and you need comfortably do convert audiofiles from all to all , you can use my solution for XMPlay https://www.un4seen.com/forum/?topic=20922.0;all , why this ? In this solution maked with uncompromising quality for compress audio files ) , also this solution can :
1) read and disassemble into tracks CUE
2) do transcode from any audio format to audio formats whitch offer in list )
3) do transcode with fully control samplerate from 8000 to 48000 Hz (this was limited because two file if was use 96000 or any other samplerate not was identicaly if do compare in Total Commander) , bitdepth 8 or 16 bits (this limited this was limited because two file if was use 24 or 32 bit was not identicaly if do compare in Total Commander )
4) my methods in low or ver low bitrates trying maximum save source data )
Important , I not author XMPlay , also I not author audio compressors , SOX , FFMPEG , and those applications whitch I use , for add-ons transcoders for audio files, but I author this graphic shell )
how use this ) run XMPlay and press shift+e or select file and press right click mouse and select tools -> transcode )
With best reggards )
Reply 1 of 33, by Roland User
And
Reply 2 of 33, by Roland User
Amd
Reply 3 of 33, by Roland User
If honestly , this not was planed , but because XMPlay me very like , II picked up the plugins whitch not conflicted , but after this I understanding what this player very comfortably in usage , and thats why I make this solutin whitch include all , free editors , free encoders and my solution for fast open , edit and transcode files )
Reply 4 of 33, by Roland User
Refreshed ) , fixed bug with wav file and add file for run as multi-thread )
Reply 5 of 33, by Roland User
Refreshed , improving logic for Vorbis if use low samplerates )
Reply 6 of 33, by Roland User
Refreshed , improvin logic and optimized MP2 codec with bitrates ) , values same , but work otherwise
Reply 7 of 33, by Roland User
Rfreshed , added AMR-WB support )
Reply 8 of 33, by Roland User
Refreshed , add LA encoder and plugin for XMPlay )
Reply 9 of 33, by Roland User
Refreshed , I was still able to add support EAC3 format in this pack )
Reply 10 of 33, by Roland User
Refreshed , I'm add support SHORTEN shn )
Reply 11 of 33, by Roland User
Refreshed , add MLP and THD , but read only mode )
Reply 12 of 33, by Roland User
Refreshed , disabled sampling in in_midi.dll , as I learned , Ian Luck fix this problem )
Reply 13 of 33, by Roland User
Refreshed , before I forgot to add SHN to half and detailed modes )
Reply 14 of 33, by Roland User
Refreshed , fixed big bugs , before transcoder was can crash if recive on input file 96000 / 24 or 192000 / 24 or any other version whitch absent in transcoders settings , now this fixed , also fixed transcode to 8 bit , before this was do rude , now accuracy )
Reply 15 of 33, by Roland User
Refreshed , I trying replace function XMP-FFMPEG.dll smaller plugins , also updated in_mp3PRO.dll to version 1.2 )
Reply 16 of 33, by Roland User
Refreshed , fixed bugs with SHN and ALAC in edit mode , and fixed bug with SHN in decode and transcode mode )
Reply 17 of 33, by Roland User
Refreshed , fix work with mid extensions , before this files was not open in Sekaiju ) , now fixed )
Reply 18 of 33, by Roland User
Refreshed , fix SPX -> SPX convertion , also fixed LPAC -> WAV extract and transcode LPAC -> LPAC and LPAC -> any other formats )
