First post, by red_avatar
I used to use Compushow (or Cshow) a lot back in the days when I messed around with Neopaint in DOS. Only problem is, it doesn't seem to work in DOSBOX. When i try to run the program, it complains that it can't find several required files which are in the folder. Any solution?
Reply 2 of 6, by red_avatar
Really? How do you manage that then? I installed the program, and it won't run on ANY of the CVS or official versions.
    80.73 KiB
Reply 4 of 6, by red_avatar
Well I thought the screenshot was pretty clear that it was installed 😉 and it's not corrupt. It's highly unlikely that any files extracted from a setup file are corrupt because it would throw up CRC errors all over the place. Besides, I got the file from several sources and they all give the same error. Could you post your own version?
Reply 6 of 6, by eL_PuSHeR
I downloaded it from ftp://ftp.elf.stuba.sk/pub/pc/graph/cshow904.zip
I don't remember if the installer gave me problems or not.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
