First post, by NeoG_
I like the idea of fluidsynth on the MT32-Pi acting more like a Roland SC-55. The classic example is the cymbal chokes in Doom E1M1, it doesn't feel right without it.
The MT32-pi project is currently at fluidsynth version 2.3.1, SC-55 style note cuts were implemented in 2.4.0 and optionalised with the synth.note-cut parameter in 2.4.3.
The plan was simple
- Checkout the mt32-pi project
- Cherry pick the commits for MSGS style note cuts since they were made while 2.3.x was the latest release
https://github.com/FluidSynth/fluidsynth/pull/1199
- Build and replace the kernel images on the SD card
Unfortunately I can't seem to execute such a simple plan, I set up a build VM and environment, set the CM4 module as the target board, cherry picked the commits for external/fluidsynth and thought I covered all the dependencies but the compiler is throwing errors that are above my pay grade.
I'm wondering if someone that already has the ability to compile MT32-Pi for the CM4L could cherry pick the commits, compile it and supply the resultant kernel*.img files?
Reply 1 of 1, by NeoG_
I did manage to brute force my way through getting mt32-pi to compile, most of the issues were caused by updates to the ARM GNU toolchain since mt32-pi was last mintained so I needed to use an older version.
I have successfully enabled the drum note cut patch into mt32-pi and it works as expected, the replacement kernel8-rpi4.img file is attached to this post if anyone else is using a Pi Cm4 (eg in the WP32 McCake)
