First post, by Mike_
I have a system built on a KT133A based Gigabyte GA-7ZXE motherboard and an Athlon XP. I'm using a SATA disk through an Aliexpress SATA/IDE adapter and it's working fine in Windows 98 SE. However, read speed is very low in DOS.
Of course this isn't a huge problem as you can run most DOS games that benefit from the extra bandwidth from Windows, but still, I wonder what's causing this.
The attachment SSTIMG01.gif is no longer available
Reply 1 of 9, by jakethompson1
UDMA is used in Win98SE (you can run SPEEDSYS HD from a Windows DOS box and get away with it and check the speed even though it admonishes you not to run it under Windows) while in DOS, the BIOS disk support generally falls back to PIO. Even then, it should not be this slow, although lack of Multiple Sectors Per Interrupt on most SSDs (assuming this SATA disk is one) hurts performance. There's no technical reason the BIOS couldn't use UDMA for Int 13h accesses, but PIO avoids having to implement VDS or triggering UDMA-related incompatibilities with picky drives.
Reply 2 of 9, by Falcosoft
Mike_ wrote on 2026-07-13, 17:09:
Actually the Athlon era VIA chipsets in PIO mode are that slow even without an adapter. You can try to load the VIA Bus Master(Ultra DMA) IDE driver from CONFIG.SYS to get better performance under DOS:
DEVICE=C:\DOS\VIAIDE.SYS
The attachment VIAIDE.zip is no longer available
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 3 of 9, by Mike_
jakethompson1 wrote on 2026-07-13, 17:19:
I tested it with HDTach and it does seem to work at about the speed you would expect from the IDE controller in Windows.
The attachment hdtach.gif is no longer available
Falcosoft wrote on 2026-07-13, 18:27:
Actually the Athlon era VIA chipsets in PIO mode are that slow even without an adapter. You can try to load the VIA Bus Master(U […]
That does work in getting disk speed in DOS to UDMA levels, but it causes Windows to fall back to "compatibility mode" for drives. I suppose this is not optimal, especially as low disk speed in pure DOS is not that big of an issue?
Reply 4 of 9, by Falcosoft
Mike_ wrote on 2026-07-13, 18:48:
I tested it with HDTach and it does seem to work at about the speed you would expect from the IDE controller in Windows. […]
You should have at least 2 CONFIG.SYS options for boot to normal Win98 and boot only to command prompt menu options.
[MENU]
menuitem=Win98, Windows 98 (Normal)
menuitem=CmdOnly, Command prompt only
menudefault=Win98, 5
[Win98]
[CmdOnly]
[COMMON]
DEVICE=C:\WINDOWS\HIMEM.SYS
DEVICE=C:\WINDOWS\IFSHLP.SYS
Website, Youtube
Reply 5 of 9, by jakethompson1
1. If "restart in MS-DOS mode" is sufficient for your needs and DEVLOAD or similar is compatible with this .SYS driver, you could try loading it from DOSSTART.BAT.
2. You could try listing it as a safe driver in c:\windows\ios.ini. Of course, if it is not actually safe, you could corrupt the file system and lose data.
Reply 6 of 9, by Mike_
To be honest, this isn't big enough of a problem that I'd want to bother with boot menu options. I'll probably want to run most DOS games from Windows' DOS box anyways, as then AWE64 can use Windows' drivers for general MIDI.
Reply 7 of 9, by maxtherabbit
Mike_ wrote on 2026-07-13, 19:54:
I think you'd find other good reasons to setup the boot menu beyond just the disk driver. If you intend to use pure DOS along with win98 it's pretty much required IMO
Reply 8 of 9, by Mike_
maxtherabbit wrote on 2026-07-13, 21:27:
I was just thinking to use restart to MS-DOS -option when a game doesn't run properly from Windows.
Reply 9 of 9, by NeoG_
Mike_ wrote on 2026-07-14, 08:19:
My personal recommendation which is me-approved is to have a restart into MS-DOS shortcut with it's own self contained MS-DOS configuration (ala Phil's easy MS-DOS shortcut), you can load it with as much dos-specific stuff you want and it never affects 9x performance or capability.
