First post, by KVMVS
Looking around online I found someone had uploaded a playable demo for unreleased game early 90s Cyberspace. I downloaded and tried to run in Dosbox but get the error message:
"Error in AddObject: Too many groups"
Before the fame fully runs.
Any idea what the issue is? Because I have never seen this before and I cannot find it for searching Dosbox help guides or Readme.
I have done all the usual config, memsize changes and mounting checks and no changes I make seem to make any difference. I even tried moving the location of both the game files and my dosbox but I get the same message.
Adding on specific information needed:
Motherboard: N/A (DOSBOX)
Processer type and speed: cputype=auto, cycles=auto (reported ~3000 in titlebar)
Amount and type of RAM: memsize=32 (32MB emulated), xms=true, ems=true, umb=true
Videoboard: Machine=svga_s3, Output=surface
Operating system: Real Host = Windows 10, DOS Box Internal DOS 0.74-3
Files: Two exe files labelled CSDEMO-.exe (231KB) and CSPACE-.exe (240KB)
Sound Mode Used: Untested - Error occurs before any audio would initialize
Vide Mode Used: Output=Surface, Windowresolution=original, fullresolution=original
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
KVMVS wrote on Today, 13:28:
It appears you have installed only patched executables. You should also install the full game/demo that includes necessary data files.
Reply 2 of 2, by KVMVS
Oh goodness of course. Thanks. It was so simple I missed it!
What it was is they split it over two download folders and I only downloaded one 😀
