First post, by Barley
Hello,
I acquired an old ASUS P8Z77-V Premium motherboard a while back and had to replace a capacitor. Once I did, it booted fine and I was able to test it out pretty thoroughly. I then put it into storage.
Last weekend, I replaced another capacitor that worked, but had physical damage. I then gave the motherboard a soap and water bath, and allowed it to dry thoroughly.
Before testing it again, I noticed a bent pin, and I have re-set it to the best of my ability. It does look to my untrained eye to be properly aligned.
Now I am receiving error code 15 and not able to get into the BIOS.
I have tried:
1. Clear CMOS
2. Reseating CPU/trying new CPU
3. Reseating RAM/trying different sticks in all slots
My only explanations are:
1. Somehow the bent pin is still not making proper contact
2. I fried something when replacing the second capacitor
3. I fried something when giving the mobo a bath.
I have highlighted the pin in red (stock photo of socket)
The attachment Untitled.png is no longer available
Here are the capacitors I replaced (stock photo of mobo)
After replacing #1, the mobo worked
After replacing #2, washing the board, and dealing with a bent pin, the mobo gave me code 15.
The attachment Untitled 1.png is no longer available
Any ideas on next steps I can take? Thanks for your help!
Reply 1 of 8, by Barley
Update: I replaced capacitor #2 in case it was installed incorrectly or faulty. No change.
I guess I'll mess around with the pin some more. What's confusing is that according to all the LGA1155 pinout diagrams I have seen, the pin in question is a VSS (ground) pin. (If someone could confirm that, I would really appreciate it!). Losing one of those shouldn't result in big issues, should it?
If that fails, my last resort is an ipa bath in case some water minerals or soap is causing a short somewhere.
If that doesn't work I think I'll just give up.
Reply 2 of 8, by cyclone3d
When I wash boards with soap and water, I use an electric blower / duster to dry it off really well afterwards.
It could be that there is something that is not dry properly or did not get rinsed all the way and caused conductive gunk and caused a short.
If that pin looks really close to how it should be, it should be just fine. There is a little bit of wiggle room for alignment.
I guess if there was some charge left somewhere and it got sent to the BIOS chip, it could have corrupted the BIOS.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 8, by Barley
Thank you for your response!
cyclone3d wrote on 2026-07-15, 20:42:
I did use an air compressor with a water/oil separator and left it in the sun for several hours.
Possibly, but I did wait several days before powering it on. Do you think an IPA bath is a good next step? Or is it too late?
Yeah, it's as close as it will ever be. I'm done messing with it.
I was gonna try a BIOS flashback next. Not sure if it will help. When I power on the motherboard, it gets stuck on code 15, but the CPU_LED light is on, and the motherboard does not beep.
Reply 4 of 8, by Barley
BIOS flashback failed, and when I pulled out the BIOS chip to try a known working one from another board, I bent and broke the pins on it.
So this board will be for spare parts. I have two other P8Z77-v Premiums. One will be my new NAS and the other will be my portable Windows XP build.
Maybe I'll get all my builds up on Vogons at some point.
*Edit* P.S.: And I've learned my lesson...no more washing motherboards!
Reply 5 of 8, by Shponglefan
In principle there is nothing wrong with giving electronics a bath. But it should only be done in cases where boards are particularly filthy and need proper removal of build-up of grime. People even use ultrasonic cleaners for this sort of thing.
I would also recommend not giving up on the diagnosis. Part of learning to repair electronics is being able to diagnose faults. If a fault was caused on the board during the washing process, it would be a good exercise to track it down.
Since the board was posting a BIOS code, this suggests it still has life in it and can potentially be repaired.
You mentioned damaging a BIOS chip when trying to remove/replace it. I would get a new BIOS chip and try again. You really have nothing to lose at this point.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 6 of 8, by Barley
Shponglefan wrote on 2026-07-16, 14:37:
In principle there is nothing wrong with giving electronics a bath. But it should only be done in cases where boards are particu […]
I appreciate your words. I just don't know what to do next. If someone is willing to help me, I'll try.
My first question is, if I do replace the BIOS chip, do I have to buy one advertised as being for my specific board, or can I buy any chip that fits the slot and reprogram it?
Reply 8 of 8, by Shadowflash
I do that all the time, especially when dealing with PCBs that suffered from leaky capacitor or battery juice or just spilled coffee, soup whatever liquid that make a good electrolyte. In fact, i did it just now - a friend brought a laptop that got an entire glass of cola on the keyboard and of course a lot of it got inside.
A good ultrasonic bath with isopropyl alcohol was all it needed, thankfully my friend was smart, so he opened that laptop and disconnected both main and CMOS batteries after it happened, I even tried to do that with a top case with a keyboard. Surprisingly it worked - keyboard works like new, even if often washing laptop keyboards don't help and you need to replace them.
That dude's sister was very lucky in this case.
All you need is to be careful and don't use maximum power when a board got lots of tiny components, and if it's a motherboard with LGA socket or any other fragile connector that doesn't need any cleaning, just cover it with something like actual socket cover or a piece of plastic bag - just don't put Kapton tape right over the socket pins.
