First post, by Almoststew1990
I have a Socket 939 Athlon 64 x2 4200 CPU with a broken (missing) pin. Looking at this diagram it is pin AL 28:
https://www.gadget-manual.com/amd/amd-cpu-pinout/
It is described as being a "memory interface" pin.
Will the CPU work without this pin? I don't want to stick it in the board as the boards and CPUs are getting more expensive so I don't want to break the CPU any more than it is already or damage the board.
Reply 1 of 3, by tehsiggi
Ping AL28 is MEMCS_2H_L[1]
This is chip select line for memory channel 2 described as DRAM Chip Selects to upper half of data bus.
The attachment Screenshot 2026-07-16 at 20.49.14.png is no longer available
So one of the four memory slots would not work.
The attachment AMD Functional Datasheet 939-Pin Package. [rev.3.03].[2005-05].pdf is no longer available
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 2 of 3, by Roman555
Almoststew1990 wrote on Today, 18:26:
I have a Socket 939 Athlon 64 x2 4200 CPU with a broken (missing) pin. Looking at this diagram it is pin AL 28: https://www.gadg […]
In general - one DIMM slot won't work. The slot which is connected to AL28 - MEMCS_2H_L[1].
But it also depends on a memory module - its volume and banks. IMHO some models of DIMM (Single Rank) will work even in this DIMM slot.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 3 of 3, by JSO
Cut a pin to the appropriate length and use it. Put it on the right hole of the socket.
I've done it to my MMx back in 1998.
DOS IS THE POWER OF OUR CHILDHOOD MEMORIES!
