First post, by doctorwhatag
1.5 years ago I built PC with following specs:
Soltek SL67EV1 motherboard, Pentium III 450 MHz Katmai, 384 MB of RAM(3 sticks by 128 MB), AGP Radeon 9200(Originally it was GeForce MX440 but it failed with artifacts), 3com Etherlink XL network card, 5-usb 2.0 PCI card, S3 ViRGE DX and ISA SB16 clone(3D Melody, which turned out to not produce sound because I forgot about -5V rail but it's not main issue for now, I can just put more modern soundcard or install that Voltage Blaster thing).
Disc drives: 80 GB Hitachi Deskstar, Fujitsu 2 GB HDD, LG IDE DVD drive
So, I installed relatively modern 2011 500w off-brand PSU in it from my other PC(which sometimes failed to power with that PSU so it was technically already bad, but I thought that with more low-power system it would work fine). It did initially worked fine, but I got issues with disc drives.
Issues: Windows got randomly corrupted with protection error, Debian install too got corrupted with GRUB2 going into rescue mode, or boot record completely not being detected or blinking "-" symbol being stuck infinitely. Even DVD sometimes failed to boot and I had to reburn it(despite other PC showing that disc is fully compilant with checksum after burning it in ImgBurn)
I firstly blamed on bad IDE cable because somehow it said that I have 40-pin cable despite it being 80-pin. So I bought ASUS and ABIT-branded IDE cables instead of noname gray 80-pin. But it didn't changed much. Additionally I thought that it could be bad IDE controller, but was(and still) unsure about this.
So I put this build on hiatus, but later I found another issue: HDD or DVD failing to spin when I connect few of drives. It beging to spin and then stops and tries to do that again. caused for system to work fine. I too thought "ah, probably IDE controller is bad and can't do stable data transfer with multiple discs". Leaving only one HDD without any other drives connected caused system to work fine. I hadn't gave it much thougt and put it on second hiatus.
But recently when I returned again to this build I decided to check MOLEX connector with multimeter. One disc power wire(that had unfortunately only one MOLEX connector, but in which HDD worked fine without respinning loop) had 5 volts, while other disc power wire with one sata power and two MOLEX with connected DVD drive that failed to spin properly showed just 4.17 volts.
I feel so stupid for missing this very obvious culprit, as it caused this issue. So now I am thinking about replacing PSU with new one. But will modern PSU handle that hardware? Are disc errors, data corruptions just as PSU issue or can IDE controller actually be faulty? Were MX440 artifact failure just random problem from age(cooling fan on it was working by the way) or were they caused by PSU? Should I be paranoid for my passive cooled Radeon 9200 failing either from overheating because I don't trust small radiator?
Setup 1: P3@450, 384 MB RAM, Radeon 9200, Soltek SL67-EV1, Etherlink XL, S3Virge(for DOS/Win3.x), SB16 clone
Setup 2: Phenom II x4 945, 8 GB DDR2, GeForce GT 640, Gigabyte GA-M61PME-S2 v.2
Hope it won't combust
Reply 1 of 15, by PD2JK
A good brand 400/500 Watt PSU should handle this system with ease. Look out for a power supply that can deliver at least 20 Amps on +5V.
has all kinds of stuff
Reply 2 of 15, by TELVM
doctorwhatag wrote on 2026-07-17, 15:17:
... will modern PSU handle that hardware?
Without a flinch. Provided the modern one you get has independent regulation, not group regulation. Have a look at this Vogons thread on the subject.
Your PIII system draws relatively little juice, less than 100W DC in total, all rails included.
... Are disc errors, data corruptions just as PSU issue or can IDE controller actually be faulty? Were MX440 artifact failure just random problem from age (cooling fan on it was working by the way) or were they caused by PSU? ...
Hard to tell, but after installing a good PSU you should have a clearer picture of the situation.
... Should I be paranoid for my passive cooled Radeon 9200 failing either from overheating because I don't trust small radiator?
Regarding electronics, it's impossible to be "too paranoid" about cooling 😀 . I'd place a small fan on that thing for peace of mind.
Let the air flow!
Reply 3 of 15, by tehsiggi
I wouldn't worry about it. I've had (and have) a bunch of 9200 with passive cooling, none of them died.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 4 of 15, by doctorwhatag
Thanks to everyone for help. I have found suitable replacement PSU(spare Frontier from my relatives) with 5v powerline of 24A. Disc drives seem to work stable as for now.
Reply 5 of 15, by doctorwhatag
UPD. PSU replacement has no issues.
But my Radeon 9200 managed to fail
Reply 7 of 15, by doctorwhatag
tehsiggi wrote on 2026-07-25, 17:45:
doctorwhatag wrote on 2026-07-25, 16:26:
In what sense?
It got artifacts, everywhere - BIOS, Windows, etc. But whole thing is very odd I guess. Before that there were no artifacts at all.
As I said in original post, I had MX440 that failed, with artifacts too. But it had fan. I am not sure if it's just my bad luck or motherboard or something else having some even worse failure that I don't know.
Radeon 9200 has no fan. But it gets very hot with just desktop, non-3D loads, heatsink like cup of tea. Artifacts appeared today, with new PSU that definitely works without problems(voltages are perfect 12v is 12.43 due to old Pentium III power load, 5v is perfectly 5.00v, checked with multimeter on Molex). They appeared while I left PC on for 40 minutes to install software.
In panic I did repaste, though it didn't looked like previous paste was bad - it transfered heat, hasn't turned into rock which I guess because seller repasted it too. It didn't help as artifacts were still there - in BIOS, Bootloader, Windows ME after cold boot. I decided to put force with my finger on heatsink of chip and four memory chips. Somehow screen got clean after I touched one of chips but I feel like it's coincidence. But it started working
Right now I out small fan near GPU heatsink on top of network card below jt and started 3DMark2000. No artifacts. Heatsink got much colder, chips too. Then I removed fan and left for few minutes, and artifacts appeared again. Stretched poligons during helicopter scene, stray pixels, etc. But not that critical. Then put fan again and they dissapeared once benchmark flushed prevous scene and loaded new. I am running it for more than 40 minutes at 1024x768 and picture looks good.
I could've just put a fan and call it a day, but I fear that artifacts don't just appear because of bad cooling and go away when you put good cooling forever. I think there has to be some catch in its sudden stability, some permanent damage done or something.
Sorry if my writing got unorganized.
Reply 8 of 15, by doctorwhatag
That's how it currently looks like. Fan is put on network card and blows into GPU heatsink.
(Unrelated: I also did little bit more electric tape cable management, replaced Pentium III fan with Gelid Silent 5 FDB-type fan and put MOLEX splitter because PSU was made when everyone moved to SATA power and it had only two MOLEX connectors)
Reply 9 of 15, by AlexZ
Don't solve artifacts with a little fan on GPU. Replace the GPU. That case can have better airflow by adding 2 fans to it. P4 era cases also have openings for a side fan. I use it in my P3 build.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 10 of 15, by TELVM
doctorwhatag wrote on 2026-07-25, 20:32:
... I put small fan near GPU heatsink on top of network card below jt and started 3DMark2000. No artifacts. Heatsink got much colder, chips too. Then I removed fan and left for few minutes, and artifacts appeared again. Stretched poligons during helicopter scene, stray pixels, etc. But not that critical. Then put fan again and they dissapeared ...
^ Well, that really sounds like this GPU needs extra cooling.
I'd attach some slim 40~60mm fan to the GPU:
file.php?mode=view&id=246341
^ (Fan is pulling just to show its label, should be pushing)
Then I'd attach tiny heatsinks on the memory chips at the back of the GPU's PCB:
file.php?mode=view&id=246342
Then I'd install case fans to improve case ventilation:
file.php?mode=view&id=246343
Heat murders electronics. Let the air flow!
Let the air flow!
Reply 12 of 15, by doctorwhatag
TELVM wrote on 2026-07-26, 17:17:
^ Well, that really sounds like this GPU needs extra cooling. […]
I have made modifications to GPU cooling. I have bought thermal pads and 4 heatsinks(it was hard because only one radio parts store sold them in my city, they were little bit mismatched and as cashier said "they were lying there in drawer for 20 years") . They are installed safely and shouldn't shift or short anything even if you flip whole PC upside down.
I have left that fan, but have made some hot glue legs(they are not glued to network cards and I have made sure they won't damage anything). Later I will try to do something more about it.
For additional test, I've played Half-Life on it for 3 hours with OpenGL rendering. Nothing crashed, no artifacts appeared.
I will put intake and exhaust fans later when I will get them. My other plan is to do some visual cleanup, so it won't look weird and buy more computer screws.
Reply 13 of 15, by TELVM
^ Ghetto-mod award of the week 😀 , but if it works, it works. 👍
Let the air flow!
Reply 14 of 15, by doctorwhatag
I made some reworks, I have installed intake and exhaust fans and redid cable management without tape. I hope I didn't miss anything important
Reply 15 of 15, by TELVM
Miles better, good job 👍 . Now the rear upper extractor fan + PSU fan will move extra cooling air around RAM, CPU, and heat sensitive CPU VRM components (transistors, chokes, capacitors), while the front lower intake fan supplies fresh air for much improved case ventilation.
file.php?mode=view&id=246743
Let the air flow!
