First post, by Inge22
Hi all,
my first post here, so wish me well 😉
I've recently installed Heretic on my win2kpro setup (check below for system specs), and I couldn't get the sound working. I've got a terratec dmx 6fire, and Crosscourt (on the Sudhian forum) advised me to install VDM sound. So I downloaded the program, ran heretic.exe with VDM support, but no sound appears, and the screen stops at the green loading indicator. So I ran setup, changed everything to 'no sound', and ran heretic.exe again, and then it works. Then I ran heretic.exe with vdm support, and it works again, but still no sound. So I ran setup.exe with vdm support, set everything at soundblaster, heretic (which is done automatically from the setup), but than the screen again stops at the green loading indicator.
Er, I wrote it quite confusing, but this is just the thing I did. Hexen gave exactly the same problem.
My question is: should I run setup.exe before trying to start up heretic, or should heretic (with vdm-support) detect the sound itself. Everything related to audio in windows works perfectly.
Also weird: the sound and midi is very simply detected in warcraft 2 with vdm support, but after that, the notification comes that there are no VESA-drivers installed. I'm also at a loss here.
The system specs can be found at http://www.students.let.uu.nl/home/i.janse/pc.htm
