First post, by Alexraptor
- Member
Been experimenting with and trying to find a decent high refresh-rate 1080p monitor that plays nice with windows XP, but haven't had much luck.
I've tried 4 different monitors so far of different brands and eras, ranging from 1st generation G-Sync 144hz monitor to a modern 360hz displays, and none seem to work "properly" with XP. Either it can't support the full range of resolutions or it's stuck at 60hz, or both as was the case with my Asus ROG Swift PG259QNR.
The two best of the lot so far has been an 144Hz Acer Predator XB270H, which has no trouble pushing 1080p@144Hz in XP but is restricted to a handful of resolutions, and a 270Hz Asus ROG Swift XG279AQM which handles ALL resolutions above 800x600 without problems, but is locked to 60hz.
Has anyone stumbled across one that actually works properly, or found a way to force proper detection of supported resolutions and refresh rates?
