First post, by ElectroSoldier
Given how an inference model stresses a GPU so much more than any game does how when will site like this start using them to benchmark PCs you think?
Im thinking MLPerf Inference, HuggingFace Optimum etc
Reply 1 of 10, by cyclone3d
The thing about benchmarks is that they have to be scripted.
Run the same query on a inference model multiple times and the results will vary and thus the load on the system will not be perfectly predictable.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 10, by ElectroSoldier
cyclone3d wrote on 2026-08-05, 20:48:
Thats why you use a Benchmark with a predictable outcome, just like game benchmarks do. Which is why I asked.
Reply 3 of 10, by cyclone3d
How are you going to make it have the same exact outcome every time though?
Inference means it infers things from the data it is fed.
I won't necessarily always come to the same conclusion or go through the same exact steps.
If it does, then it is not inference anymore.
YMF7x4 Guide
Reply 4 of 10, by ElectroSoldier
Thats like saying you cant benchmark a game because in the game world you never get the exact same frame twice!
You can benchmark things like tokens per second, batch performance, memory efficiency, parallel requests, context window, VRAM usuage, model load times,
Reply 5 of 10, by cyclone3d
The game benchmarks use scripted runs... Aka, the frames should be exactly the same every single run.
Yes, you could test those things, but how is that actually benching, in a repeatable way, the inference model itself? If the model takes different paths to come to a result, the speed at which it completes that exact prompt that was used for the bench, the time to completion may be wildly different from run to run.
And what if you have a mixed CPU and GPU setup where things can spill over to another asset if one or more run out of resources. If the RAM usage is different between runs, the assets used could also be different thus affecting the benchmark scores.
At the very least, you would need to take an average over many runs with th same exact prompt and any acquired "training" resulting from the prompt being run, erased between runs.
YMF7x4 Guide
Reply 6 of 10, by ratfink
Maybe a shorter answer is "when that sort of benchmarking has some relevance to what the site is about".
Reply 7 of 10, by ElectroSoldier
cyclone3d wrote on 2026-08-06, 04:26:
The game benchmarks use scripted runs... Aka, the frames should be exactly the same every single run. […]
I don't know where to start on this one.
An inference model is already trained, that part is finished. When you run it locally, you’re not training anything, you’re just doing a forward pass through fixed weights. Nothing inside the model changes between runs.
If you have a mixed CPU/GPU setup because the GPU can’t hold the whole model, then that’s simply the hardware configuration you’re benchmarking. It doesn’t “test the card differently” depending on the output. The workload per token is identical.
An inference model isn’t like a game engine. Games have to process the same sequence of frames to make a benchmark meaningful, because the amount of work changes depending on what’s on screen. LLMs don’t work that way.
With an inference model, whether it’s text to image, image to image, or an LLM writing a 10 page fantasy in the style of Poe the content of the output might change, but the amount of computation per token does not. A image of a zebra or an ocean doesn’t change the math. A different sentence doesn’t change the math. The model always performs the same operations for each token.
So even if the output varies, the computational workload is the same, which is why tokens per second is a valid and repeatable benchmark.
ratfink wrote on 2026-08-06, 05:02:
Oh I'm very sorry... Next time I'll be sure to make sure it's about games and nothing but. But just for you!
For now in this thread maybe we can talk about benchmarking for inference models as they stress GPUs much much more than games do to the point where many GPUs that are still considered current for games played today are pitifully underpowered when considering an inference model.
Reply 8 of 10, by cyclone3d
Ok, looking up stuff more, it is possible to have a model get trained by the input prompts, but is not normally done.
After a bit of back and forth, this is what ChatGPT output for a list of best practices for benching inference and I learned some things along the way.
Best practices for benchmarking LLM inference
1. Define what you are testing
Run separate tests for:
Cold start: model load through completed response
Warm inference: model already loaded, fresh request state
Prompt-cached inference: repeated prefix caching enabled
Sustained throughput: continuous requests over a longer period
For most practical comparisons, warm inference with a fresh KV cache is the most useful test.
2. Keep the test conditions fixed
Use the same:
Model and quantization
Inference software and version
Prompt and system prompt
Context length
Maximum generated-token count
Sampling settings
Hardware power and performance settings
Number of simultaneous requests
Speculative-decoding configuration
Use deterministic decoding where possible, such as greedy decoding or temperature 0.
3. Control caching correctly
For a standard warm-inference benchmark:
Keep the model loaded
Perform several warm-up runs first
Start each measured request with a fresh KV cache
Disable prompt or prefix caching
Disable response caching
Do not flush the operating-system disk cache
Do not unload and reload the model between runs
Show last 142 lines
Do not clear the GPU allocator cache between every run unless that is specifically what you are testing
For a cold-start benchmark, restart the inference process before every measured run.
4. Control output length
Output length strongly affects total time.
Best options:
Force the same number of generated tokens
Use a prompt unlikely to produce an early stop
Disable early stopping or stop strings when possible
Record the actual generated-token count for every run
Do not compare total completion times when the models generate substantially different numbers of tokens.
5. Warm up before measuring
Before collecting results:
Load the model
Run the exact workload several times
Allow kernels, memory allocations, and GPU clocks to stabilize
Exclude warm-up runs from the results
6. Measure the right metrics
Record:
Time to first token
Prompt-processing speed, in input tokens per second
Generation speed, in output tokens per second
End-to-end latency
Actual input and output token counts
Peak memory usage
Power consumption, when efficiency matters
For concurrent testing, also measure total system throughput and latency percentiles.
7. Run enough repetitions
Use at least:
3–5 warm-up runs
10 or more measured runs
More runs when results vary noticeably
Report:
Median
Mean
Minimum and maximum
Standard deviation or percentile spread
The median is generally more useful than reporting the fastest run.
8. Keep the system stable
During testing:
Stop unnecessary workloads
Use a consistent power profile
Avoid thermal throttling
Monitor GPU temperature, clocks, power, and utilization
Keep CPU affinity and thread counts consistent
Keep the same NUMA configuration
Avoid changing GPU offload or batch settings between comparisons
9. Test realistic prompt sizes
Benchmark several workloads rather than one tiny prompt:
Short prompt, short response
Long prompt, short response
Short prompt, long response
Long prompt, long response
This separates prompt-processing performance from token-generation performance.
Recommended default procedure
1. Load the model once.
2. Disable response and prefix caching.
3. Use a fresh KV cache for every request.
4. Fix the prompt, context, sampling settings, and generated-token count.
5. Run five unmeasured warm-up requests.
6. Run at least ten measured requests.
7. Record time to first token, prompt speed, generation speed, and total latency.
8. Report the median and variation.
9. Test cold-start and cached-prefix performance separately.
[\code]
YMF7x4 Guide
Reply 9 of 10, by ratfink
ElectroSoldier wrote on 2026-08-06, 06:11:
I answered your question, what IS your problem?
Reply 10 of 10, by ElectroSoldier
ratfink wrote on 2026-08-06, 08:43:
But we talk about a lot more than just Very Old Games On New Systems on this site.
Your answer makes it sound like any talk other than that isnt wanted.
