First post, by fiasn
Just got an Inspiron 5000 for pretty cheap off ebay, but it seems to be dead as a doornail. At first, it would blink the battery LED continuously and not do anything, but now it seems to attempt to turn on for a split second? It makes a click and a static-like noise as if it was trying to do something. I pulled the CPU module out and it will power on without it, then i saw a wonderful burn mark on one of the Vcc lines, which makes me think that there is a short somewhere. Is it likely that it's just the MMC-2 module that failed, or is the whole system toast?
Dimension 4100, Pentium III-EB 1GHz, i815e, 512mb PC133 CL3, GeForce2 Pro 64MB, SBLive! 5.1, VIA VT6212L USB2.0
Latitude C610, Pentium III-M 1.2GHz (Tualatin), i830MP, 768MB PC133 CL2, Mobility Radeon 7000 16MB (128bit)
PMG4 Dual 866MHz, FX5200, 2GB DDR
Reply 1 of 1, by fiasn
I should specify that this is a Pentium III laptop, not the newer junk 5000 series.
