First post, by charlysan
I have been experimenting with this cheap Waveshare RP2350 board, which includes a DVI port. Inspired by rgb2hdmi, I have been able to put together some firmware and a basic circuit to capture TTL video and output it over HDMI, with pretty good results.
So far, I've tested it with HGC, CGA, and Commodore 128. Multiple parameters can be configured using the serial console, as explained in the README file. There is no EGA implementation at the moment (because I don't have any card in good shape), but I plan to include it soon.
I might also add some basic DIP and SMD PCB designs in the future.
I shared the project in GitHub:
https://github.com/charlysan/pico-ttl2dvi
Reply 1 of 6, by keenmaster486
Very cool. I've been hoping someone would do something like this.
How far can you go with input vs. output resolutions? Is VGA from the feature connector a possibility?
World's foremost 486 enjoyer.
Reply 2 of 6, by charlysan
keenmaster486 wrote on 2026-08-07, 17:33:
PicoDVI is tied to sysclk. 800x600 would need ~400MHz sysclk. RP2350 is specified at 150MHz, and we are already overclocking to 260MHz here. Using HSTX might give us more room, (but it can't be done with this board and builtin dvi connector). Using Adafruit Feather RP2350 with HSTX Port might be an option. But, do we really need to go that far for this retro TTL video use case?
I didn't understand your question related to VGA. Are you talking about DE15 connector?
Reply 3 of 6, by wbahnassi
Nice device, it cries for CRT effects though... at least scanlines.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 4 of 6, by keenmaster486
Honestly, 800x600 is not really necessary, I'm thinking of 400 and 480 line modes. The big problem to solve with VGA is near-instant transition between 720x400 text mode and 640x400, 320x200 (line doubled), or 640x480 graphics modes, without requiring adjustment after a mode change to fix the sampling alignment and restore uniform pixel sizes. This is also a problem with EGA, as there are two EGA modes, 200 lines and 350 lines, but those do have the same horizontal pixel count (320/640).
The feature connector is an internal pinout on VGA cards that exposes pre-RAMDAC digital video out - not sure if it's exactly the same as TTL from an EGA card, but it has RGB and H/V sync iirc.
Reply 5 of 6, by charlysan
wbahnassi wrote on 2026-08-07, 19:11:
Yes. Already tried scanlines emulation in MDA mode (although not implemented in the right way, it was just a quick test). I will include the feature in next revision. But not sure if it will be straight forward for all the modes.
Reply 6 of 6, by charlysan
keenmaster486 wrote on 2026-08-07, 19:15:
Oh, that edge connector. Interesting...
