First post, by 5a796d
5a796d
Offline
The fix corrects the game's internal calculations to use 64-bit arithmetic (which doesn't overflow for hundreds of thousands of years), and also applies a small "realignment" every 30 minutes that prevents the value from ever approaching the critical limit, without any noticeable disruptions in the game.
Tested stable for over an hour of continuous gameplay, with no framerate drops, speedups, or side effects on physics, animations, or tire wear.
Tested on 64-bit Windows 10.
This fix works only on 64-bit systems. It may or may not work on systems older than Windows 10.
https://community.pcgamingwiki.com/files/file … bit-systems-v2/
