First post, by CarCrasher
Hi
This isn't really a dgvoodoo problem or thing but I'm wondering would it be possible for you to merge the Chicken Run fix you made (this one: Wants to create textures with size of 0x0 and crashes because of failed factoring. I don't know why it is but I patched the executable. Seems to work both through dgVoodoo and natively on Win10 https://dege.freeweb.hu/Patches/bin/Chi ... tched.zip) with the no-cd/fixed exe from GameCopyWorld (https://gamecopyworld.com/games/pc_chicken_run.shtml). And well the reason I'm asking for this is because for some reason that particular exe would load the audio and video folders if copied over from disc/iso to the game folder by that I mean going to the disc/iso and copying over the video folder containing all the bik video files and the audio folder separated by language containing all the .ima files to the data folder in the Chicken Run game (Eg. Chicken Run\data\audio\eng or Chicken Run\data\video). With that exe you could have the intro videos play and hear the characters talk with eachother without needing to have the iso mounted or disc inserted. For some reason tho this doesn't work with your patched exe you would need to have the iso or disc mounted to hear the sounds (Since the game itself came on a mixed mode cd the soundtrack is also contained on the CD, unfortunately just having the iso mounted doesn't really do anything to fix but atleast there is a fix on MyAbandonware made with OGG-WinMM so you can hear the songs without an actual game disc https://d1.xp.myabandonware.com/t/0be50b2d-25 … -Game-Music.zip) So yeah I'm wondering if its possible to combine them into two so you could play Chicken Run on modern windows without it instantly crashing but also having all the songs, intro videos and character sfx play without needing the iso mounted.
