VDDloader.dll wont load
First post, by Unregistered
Every time I try to run a program with VDMS, (right click, menu pops up, run with VDMS) one of two things happens. A) I get a black dosbox, which is empty, or B) I get
VDMSound DOS loader, version 2.01 (Aug 04 2001)
Copyright....
VDMSound is covered...
published by the Free....
And then somtimes I wil get a message saying that VDDloader.dll is loading, but it will never get past this point. Been working on the problem for bout 4 hours now, and cant seem to get anywhere, any suggestions or fixes would be much appreciated.
I'm running the following:
Win XP, DX9
AMD Tbird 1.33 Ghz, 384 ram
Geforce 2 MX400
onboard legacy, sounblaster 16
soundblaster live PCI card
Have also tried uninstalling and reisntalling the launchpad, and hjave updated to version 1 of VDMS 2.04.
And though it probably wont do any good, 'cept for making this a longer file, heres the verborse (set to 0 in the debug option) VDMS.log file through several tries.
@I - 00:04:17.539 - VDMServicesProvider
VDMServices initialized (hInstance = 0x02ea0000)
@I - 00:01:58.829 - VDMServicesProvider
@I - 00:04:25.696 - VDMServicesProvider
VDMServices initialized (hInstance = 0x02eb0000)
@I - 00:05:37.925 - VDMServicesProvider
VDMServices initialized (hInstance = 0x02a90000)
@I - 00:06:23.119 - VDMServicesProvider
@I - 00:06:23.129 - SysEx Indicator
ActivityLights initialized
@I - 00:06:23.240 - MIDI Player
MIDIOut initialized (device ID = -1, 'Microsoft MIDI Mapper')
@I - 00:06:23.280 - MIDI Player
Garbage collector thread created (handle = 0x00000174, ID = 1420)
@I - 00:06:23.280 - MIDI Mapper
MIDIMapper initialized
@I - 00:06:23.340 - DMA Transfer Manager
Transfer Manager thread created (handle = 0x00000184, ID = 1464)
TransferMgr initialized (minPeriod = 5ms, maxPeriod = 15ms)
@I - 00:06:23.520 - AdLib Wave Player
WaveOut initialized (device ID = -1, 'Primary Sound Driver / ')
@I - 00:06:23.580 - AdLib Wave Player
Garbage collector thread created (handle = 0x00000194, ID = 2012)
@I - 00:06:23.580 - AdLib Controller
Using performance counter (1193182 ticks/s) for AdLib timing
Playback thread created (handle = 0x00000198, ID = 388)
AdLibCtl initialized (base port = 0x388)
Reply 1 of 5, by Nicht Sehr Gut
Probably need Vlad's help with this, but I noticed you have DirectX 9. Problems seem to skyrocket with DOS programs after DX9 (not for everybody...but still...)
Reply 2 of 5, by Unregistered
Still having the same stupid problems, and I have all these abandware games just waiting to be played.
A couple questions:
Is there anyway that my BIOS settings for the onboard sound (which is MPU-401 and a soundblaster 16 I believe) could conflict with allowing VDMsound to run? I have them currently disabled.
Does VDMsound require a free IRQ to run properly, or does it emulate on through the software and then push it out to DX?
Could RunDLL32 be the problem, an how would I go about replacing it if it is?
As far as I have been able to trace, the program seems to hang up after calling ntvdm(vddloader.dll) (if i remember correctly anyways), could this have anything to do with it?
thanks for any help, and good job with th site
Reply 4 of 5, by Unregistered
Not as far as I know, but I might have had one in the past that I uninstalled. Just to be sure, any idea what file names a mmon would use? I'll take a look into the registry as well.
Reply 5 of 5, by Nicht Sehr Gut
If you find files like USERPORT.SYS or GIVEIO.SYS, those will kill SB emulation.
