Thanks tehsiggi.
tehsiggi wrote on 2026-08-19, 11:38:... Since the connectors are physically the same, I'd assume similar specs ...
^ Yep, that stands to reason.
Interestingly the max current limits for VCC3.3, VCC5 & VCC12 are the same in AGP 3.0:
6 amps @ 3.3V are 19.8 watts.
Some of those "Shevalier's favourites" 😀 linear regulator cards blatantly exceeded this limit:
shevalier wrote on 2026-08-18, 09:53:... Now, an FX5500 on linear regulators — that’s impressive.It probably draws around 50 watts. 😀 ...
Provided extra good cooling, you can get away with some overloading ... but only up to some point before the RBMK reactor starts melting down 😀 .
