First post, by Dusko
- Member
Hi all!
I wanted to share a DOS mixer I created for the Orpheus II sound card.
It's called OP2MIX.COM, and it allows you to see and change the current volume levels, turn SRS on or off, and see the current configuration of the card.
OP2MIX is an Orpheus II mixer, not an initialization program. To switch between modes (SB, OPL3/CrystalFM, WSS, etc.), you'll still need to run ORPHINIT.
And just a quick disclaimer: OP2MIX is provided as-is, so use it at your own risk. I’m not responsible for any damage or unexpected behavior that may result from using it.
Video: https://youtu.be/TKtmdsRjBfI
08/25/26
Update to version 1.721
OP2MIX.COM Download: https://app.box.com/s/exokw0u483v8t75mx2s2uvfjqjy0egvr
Updated Screenshots (v1.721)
Retro PC games channel: http://www.youtube.com/@myRetroPC
Electronics, mods and tools channel: https://www.youtube.com/@RetroRust-75
Reddit: https://www.reddit.com/r/MyRetroPC
FaceBook: https://www.facebook.com/myretropc
