First post, by quwy
Hi, All!
Got the motherboard DataExpert EXP8449, and after several evenings of restoration, it at least passed POST and let me to run tests and install OS-es.
And after some time I accumulated set of very strangest properties, related to the RAM work. I'll list them as the oddities increase.
1. One 8-MB SIMM BIOS show as 7808 KB.
2. Two 8-MB SIMMs BIOS show as 16000 KB (not 16384 as usual).
3. L2-specific fall on the memory bench graph seen only for 'move' operation; 'read' graph after L1 fall remains direct; 'write' graph absolutely direct on whole width.
4. BIOS summary table show 15360 KB of extended memory (most DOS tools repeat this value).
4. Win98 says about 16.0 MB of system RAM.
5. WinNT4 on the boot screen and system props says about 14 MB of RAM (and it feels like that's how it is, it's a bit slow).
6. Speedsys also show 14 MB of RAM.
7. Memtest86 says about exactly 13368 KB of RAM.
Mobo has AMI BIOS with graphical windows-style setup, but no one option does not affect such memory ambiguity.
What is it? Where does this difference come from?
VMT/VMTCE & ChkFlsh author.
Reply 1 of 5, by NeoG_
quwy wrote on 2026-08-25, 01:22:
The BIOS is choosing to ignore the 384KB of memory space used for hardware communication, nothing unusual. 16000KB + 384KB = 16,384KB
I think this is normal , the first 1024KB is used for the real mode memory map and can't be re-used for EMS/XMS. Nothing usnusual here either. 1024KB + 15360KB = 16,384KB
Fine, 16.0MB is installed because it can use a different interface to query installed memory, but it probably can't use all of it due to the mentioned reservations
Windows NT and speedsys are probably using the same memory calculation method, and are reporting how much memory they have available minus any reservations
Since memtest86 needs to reside inside memory, it cannot ever test the full amount lest it delete itself while testing. So the difference is likely available memory plus a location for itself to reside.
I don't think there are any issues here. You can check if "Memory Hole at 15M" is enabled in the BIOS, that will remove 1MB of RAM from being available.
Reply 2 of 5, by jakethompson1
Hello,
In period-correct times I wondered about this also.
AMI BIOS subtracts "shadow RAM" from the amount of displayed RAM. Award BIOS does not. So you will see these oddball amounts on AMI, but an even number of megabytes with Award.
On PCI boards, like yours, the entire block from 640K-1024K (so 384K) is taken up as shadow RAM and is therefore subtracted from the allocation.
Older chipsets often have memory relocation, in which A0000-BFFFF and D0000-EFFFF (256K in total) gets relocated to the very top of memory, while C0000-CFFFF and F0000-FFFFF (128K) is consumed as shadow RAM. My UMC 481 board is like this, so AMI reports 8064 K.
Reply 3 of 5, by quwy
NeoG_ wrote on 2026-08-25, 02:04:
Ok, I think by same way. But it first time when I see suck calculation. All another AMI-based boards (from 386 to P6) shows traditional value.
Yes, in is normal, I wrote this value here only to compare with another sources.
IMHO Win9x systems are not a model of correct interaction with RAM and there is a high probability what this value just calculated by same way and from the same source as DOS diagnostic tools.
2 MB of reservation on 486 system?! Only 1MB S3 PCI video card inserted, nothing else.
In 1995, for stealing two megabytes of RAM, any manufacturer would have been instantly thrown out of the market.
I just now removed one SIMM and as I suspected, there are only 6 MB left for NT. It was nonsense at that time.
Ok, this still mean what only ~14 MB is available, regardless what Win98 think about this.
I know about this option, but it doesn't exist.
Reply 5 of 5, by quwy
jakethompson1 wrote on 2026-08-25, 02:09:
Around 1995 it was unthinkable to just give up two megabytes of memory.
I remember how much it cost and how we fought for every KB.
Windows 9x was known to round to nearest 4MB
This explains "16.0 MB" on the system properties window.
MEM
"Total memory: 16384 KB"
