First post, by Dusko
- Member
Hello,
These are some DOS (.COM) files I created to test the L/R channels of my sound cards, and I wanted to share them here.
Disclaimer: These files are provided "as-is", so use them at your own risk. I’m not responsible for any damage or unexpected behavior that may result from using them.
These files are also useful for testing the current volume levels, as they don't change any of the sound card's volume settings, as most games do.
PCMPLAY.COM
https://app.box.com/s/5xgft3my7iw2xefqn69heqa1fmvn16pq
This program tests the PCM (or wave) audio of the sound card. It uses the classic Sound Blaster settings: port 220, IRQ 5, and DMA 1, but you can change those with command-line switches.
It can also test Windows Sound System (WSS) audio. (Run PCMPLAY WSS) For help, run PCMPLAY ?
FMLR.COM
https://app.box.com/s/jrrx7koi7m1dw5iyf5fjo42p1l5d602r
This one may be a bit controversial, as some cards will swap the L/R channels. For help, run FMLR ?
It's based on the Yamaha OPL3. I tested it with my SB Pro and SB16, and it plays the L/R channels correctly on both.
The default port is 388, but if it plays in mono, as it does on my SB Pro, change the port to 220 (run FMLR P:220). That will make it play correctly in stereo.
PCSPKR.COM
https://app.box.com/s/cfpax5qu8wfw84ycio5c1ruv07pq8mo2
Tests the PC Speaker. For Help run PCSPKR ?
MIDILR.COM
https://app.box.com/s/3vmngzadxgmsf4hvnezjr1edq8ouzte6
Tests the GM MIDI L/R channels. It also tests Roland MT-32 (run MIDILR MT32). For Help run MIDILR ?
I hope you find them as useful as I have, and let me know if they work for your particular setup.
Dusko.
Retro PC games channel: http://www.youtube.com/@myRetroPC
Electronics, mods and tools channel: https://www.youtube.com/@RetroRust-75
Reddit: https://www.reddit.com/r/MyRetroPC
FaceBook: https://www.facebook.com/myretropc
