First post, by Digidreamer
Hi, Thought I’d introduce my latest build.
Been thinking about this for a while, had parts to use up,
Scope, to convert a Tonka/Kenner Millennium Falcon to a Retro Windows 98SE PC
I wanted to achieve this sympathetically to the falcon, with minimal adaptions to the exterior, also with minimal cables. Did it with 2, power and monitor. I’ve seen some “messy” attempts on the web, I will try to do better.
My start is the 1995 model Tonka POTF, bought from a certain online auction, mostly complete (Think I'd get lynched if used an original 1970's version).
The board used was a Wyse VX0L board with the 16mb 7000 ATI Graphics module, this did away with trying to house a PSU internally, the board is essentially a Via ITX Motherboard.
Dismantling was easy, just unscrewed the 2 halves, removing the card interior wall, cut away some of the interior plastic work, and relocate the speaker, used some hd rubber foam blocks cut and inserted in the rear landing gear housings to stop the extra weight collapsing the landing gear.
The motherboard fitted neatly between the “landing gear” housings.
Used some aluminium angle to fabricate brackets to mount the motherboard to the main shell, chose to screw them to the rear landing gear housings, and epoxy the “front Bracket” to the lower shell and glued the front landing gear to the bracket (Don’t want it moving).
Installed a battery eliminator to the battery box, so I could use the USB to power the sounds and lights.
Removed the cockpit bulkhead and glass, and installed a small fan (probably not needed but didn’t want to chance it over heating) Fitted the power and HD Leds(3mm) to the cockpit “cup holders” (Nice idea to have cup holders),
Used a USB powered A2DP adaptor to give me Bluetooth sound not otherwise available on Windows 98se (One cable less).
Needed an accessible power switch, so tried to hide in in the exterior design, fitting a small circuit board, side cut away to allow the switch to protrude,
Fitted a power socket to one of the "refueling points" on the underside then connected the fan and motherboard power cables,
Quick tidy of the cables, fitted a CF card adaptor, fitted a wireless keyboard and bouse adaptor, (another 2 more cables saved) nusb36 Windows 98 USB stack supports a wide range of Keyboards etc. then had to cut access for the video cable (Unavoidable just had to keep it tidy)
Reassemble the main shell, I already had the OS setup for this board.
Laser cannons need to be modified and reattached. Used blue reflective tape for the engine exhausts (Looks cool with the right lighting).
everything works (Wahey!!)
This all took me several weeks, when I had some spare time.
I Like Charity Shops, they're like steam and GOG but cheaper.
Dos 6.2 - HP7510 512Mb, 4Gb
Reply 1 of 10, by Digidreamer
part 2
Blue square on the gray plastic next to the cockpit is the power switch (Subtle).
Only issues are HDD led only works with a hard drive fitted, and the fans on permanently as board doesn't have a fan header the only accessable was the 12v main feed
Reply 2 of 10, by Nexxen
Nice!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 3 of 10, by H3nrik V!
That is so fogging cool, combining the finest hobby with the greatest universe of all time. Kudos!
It's a shame your png images are only 256 color. I'd like to see even more!
Reply 4 of 10, by revolstar
What a wonderfully crazy idea! 😁 I think a short video presentation would do it even more justice!
Win95 rig: Pentium II 400/64MB RAM/Matrox G400 16MB/Voodoo2 12MB/SB Live! + SB 128
Win98 rig: Athlon XP 2500+/512MB RAM/SB Audigy/GF FX5700
WinXP rig: HP RP5800 - Pentium G850/2GB RAM/GF GT530 1GB
Amiga: A600/2MB RAM
PS2, Ps3, Dreamcast
Reply 5 of 10, by Irinikus
Very Nice! 😀
YouTube
Reply 6 of 10, by Digidreamer
Got some full colour assembly shots,
I'll need to some fresh complete shots,
Going to change the fan to usb so it shuts down when the pc is off
Reply 7 of 10, by Digidreamer
Nearly complete, the minimalist desktop.
Tried to up load video, but not allowed here,
Testing a glide wrapper, working well. Couldn't get any to work on the Via chip set
Specs
CPU Via C7 800mhz
Graphics ATI 7000 16mb (PCI module)
Sound onboard chipset
Ram 512mb
storage 8gb CF card
Audio self contained Bluetooth A2DP Adapter
Video HDMI (DVI to HDMI adapter, no audio)
Keyboard/Mouse USB wireless
Reply 8 of 10, by H3nrik V!
A long time ago in a galaxy far, far away
A person with the hobby of retro computing built one of the coolest looking setups ever ..
Reply 9 of 10, by Digidreamer
Final assembly,
Usb fan fitted with a charge splitter with the original sound and light effects, working from the motherboard header.
A2DP Adapter sorted on a USB power only connection from the header (no D- D+).
So everything powers down. When the motherboard is turned off.
Keyboard and mouse adapter fitted to the top of the landing gear strut so it can be replaced without opening everything up, (bit fiddly).
Just some testing, then going up for sale. To fund next project
Reply 10 of 10, by Digidreamer
Ok ready with the next project hp 5710 powered Hasbro falcon, similar spec but with dos sound and game port.
This one's Vx0l falcon has been listed of fleabay if anyone's interested.
