Wave Router
First post, by Roland User
Hi )
I create Wave Router ) this work also as MIDI Router , can do Equalize and recored tracks per port )
You can do :
1) route any wave streams from play device to record devie ) for example VAC devices
2) do equalize this stream
3) do gain , preamplification stream or weakening stream
4) do record from input devices as is or in DVD format 48000 / 16
5) apply low pass and high pass filters
6) set sample latency in samples
Enhanced compatibility with Windows XP )
From latency removed samples ) , now this work so :
Silence generator with latency 512 samples
44100 / 48000 - latency 2048 samples
88200 / 96000 - latency 4096 samples
176400 / 192000 - latency 8192 samples
added paning mode for use USB devices for example USB speackers or Bluetootch speackers )
added reset buttons in CMP /HP / LP /EQ / WID
added effects : Reverb / Chorrus / Echo Delays / Flanger / Distortion / Pitch Shifter / Ring Modulator / Frequency Shifter / Wah-wah / Vocal Morpher / Phaser / Tremolo / Vibrato / Rotary Speaker / Noise Gate / De-Esser / Ping-Pong Delay / Bit Selector
and this not all , that so why all effects will enhanced ) now this only base versions )
added X-Fi Crystalizer and Vitalizer )
2.0 .build 2066
Fixed AWE3DSE , before if set values from keyboard and next click to other element , value was can reset to 3% , now this fixed )
2.0 .build 2033
Fixed De-Esser logic
Added AWE3DSE , this effect do any MP3 song very ugly , but as far as I remember , so was work 3DSE on my AWE64 )
2.0 .build 1966
Fixed Noise Gate was not saving , Scout mode was notr saving . EQ was work not correctly , for example 1 KHz -12 dB and 1 KHz +12 dB not was zero value
Added 3DSE mode in button WID
2.0 .build 1933
Fixed very long time reverb decay if more then 10 sec )
2.0 .build 1866
Reverb decay expand to 20 sec as maked in Audigy RX ) , warning , previous values will be doubled , because you need open FX -> Reverb and do re change value how you want )
2.0 .build 1833
Fixed visual bug on reverb page 3 , this not affects work performance , and not such critiacal fix ) more like cosmetics fix )
2.0 .build 1766
Improved X-Fi Crystalizer and Vilatizer , before on low values was distortion of sound
2.0 .build 1733
Added De-Filter in Noise Gate )
2.0 .build 1666
Separated Normalizer and Comprerssor , added Vitalizer )
2.0 .build 1633
Added Restoration Suite De-Click , De-Clip , De-Hum , this in FX -> Noise Gate , also fixed Vocal Morpher before in Vocal Morper mode was range A-E , now fixed and expanded range A-U )
2.0 .build 1566
Added Scout Mode with step 1 Hz ) , this in button CMP )
2.0 .build 1533
Added X-Fi Crystalizer with step 1 Hz ) , this in button CMP )
2.0 .build 1466
Fixed , now Wave Router do automatic reselect devices in pairs )
2.0 .build 1433
Fixed last hard bug , if select samplerate in LAT , was freeze if before this was canged diffirent sample rate in Windows -> Sound -> Playback -> SoundCable -> Other -> Frequency and for example do reselect 44100 -> 48000 or 44100 -> 48000 -> 44100 or 48000 -> 44100 -> 48000 , and next press to AMP and trying , now all work correctly m, but added 2 second delay , this need for not freeze GUI and worker thread )
2.0 .build 1366
Hard bug fixed in previous verrsions if do reselct freuency in Windows -> Sound -> Playback -> SoundCable -> Other -> Frequency and do reselect 44100 -> 48000 or 44100 -> 48000 -> 44100 or 48000 -> 44100 -> 48000 , and next press to AMP and trying change value - was freeze Wave Router GUI
2.0 .build 1333
Fixed 24 band Equalizer bands 17-24 was not correctly work - now fixed
Improved Ring Modulator , Frequency Shifter , Surgical De-Esser , now step 1 Hz
Rollback to 2.0 .build 1266
fixed EQ alhorytm , now this work correctly and without delays , only MME version ) , by the way , I finded not planed feature if you hearing melody with two instruments with one instrument per channel , you can in WID do mono channel with one of instruments... for this need use L-R or L+R mode and use pan mode , and next do paning to one of side , then you can hear only so partial whitch in side in whitch you will do moved slider ) and this partial will play as mono channel in both channels )
Spoiler
This some kind of curse!
I can not correctly make MME and WASAPI modes in Wave Router , when so , then I get micro lags in output sound..
That so why do rollback to 2.0 build 1266
I will trying make version 3.0 , but only with corectly WASAPI mode , I understanding what need make separate files for WASAPI and what not need do mix MME and WASAPI logics in one branch files
3.0 build 160
added very smoth auto gain control )
Rollback to 2.0 .build 1233
removed WASAPI , because this maked problems , when I use MME structure , I not get flow disruptions , but in WASAPI versioin I get flow disruptions , I understand what need 16 circular buffers for correct work this Wave Router
3.0 buld 128
added key /forcemme , if need test and compare in Vista+ )
3.0 buld 096
fixed CMP , now not active elements gray )
3.0 buld 064
fixed normalizer in button CMP )
3.0 buld 032
added support WASAPI Shared )
2.0 build 1166
fixed WID button , now Wave Router do correctly saving paning values , also was improved WID mode , now this opened faster then was before )
2.0 build 1133
fixed bug with 2% step in first 8 effects , now make correctly 1% step in settings )
2.0 build 1066
reworked algorithms now correctrly work all variants , now you can do mix original + effect or effect + original ) , always )
2.0 build 1033
added tryple and quadruple delays as in insert of Roland SoundCanvas VA )
2.0 build 966
now effects started more flexibility ) now you can select not only value of effects from tremolo to rotary speaker , now you can mix original sound volume and effects volume )
2.0 build 933
added Humanizer , this effect in Vocal Morpher ) , also improved reverberation , now you can select accuracy 0.1 dB and 0,01 meters in roomsize
2.0 build 866
Removed Lo-Fi , because this replaced to Bit Selector , this module include Lo Fi and Upsampler , you can select bit depth from 1 bit to 32 fp bit , default value bypass with intrnal bitdepth of DSP 32 bit float )
Improved Distrotion module , added amplifer seelct ) you can do select style of distortion from Overdrive to Fuzz , you can select cut off from any values , but you now can select and amplifer )
2.0 build 833
DSP Improved , added custom values from keyboard to chorrus , flanger , pitch-shifter, tremolo , virato , rotary speaker , noise gate , de-esser , ping-pong delay , lofi
also added function statup DSP on selcted pair , with this optin be careful last may be not predictable , range may be from your strong increase and up to damage your hardware or your health
2.0 build 766
DSP mproed reverb , now very flexible )
2.0 build 733
added :
Phaser
Tremolo
Vibrato
Rotary Speaker
Noise Gate
De-Esser
Ping-Pong Delay
Lofi
2.0.RC10 , very improved flexibility ) now all effects fully flexibility ) you can select on EFX Distortion from soft overdrive to hard Fuzz and this very smooth , same work and other effects ) , for example you can select waveform from sinusid t osquare in Reng motulation , and so in all )
Wave Router 2.0 enhanced DSP , effects always work on 44100 or 48000 . this frequency always even if select 88200 / 96000 / 176400 / 19200 ) and in current version absent bug with user do rechange samplerate in Windows Multimedia )
Refreshed , fixed small bug with first set Pitch Shifter )
2.0.RC9 chorrus and flanger was reworked , now you can select dry / wet signals diffirent )
2.0.RC8 fully independed DSP )
2.0.RC7 DSP was expanded up to 8 independed bus ) this mean wat you can impose cascades of efx , include same efx on diffirent ports )
2.0.RC4 fixed lot bug if use two mono speacker , before was copy signal , and user can get double mono )
2.0.RC3 fixed lot bugs , now I will do delay as in Audigy RX ) , fixed Distortion EFX )
My next plans on version 2.0 , I want add Creative X-Fi Crystalizer , 3DSE and Scout mode ) , version 3.0 with WASAPI more likely will aborted... this mean what according to my plans will expand version 2.0 and next version will 4.0 with skiping 3.0 , version 4.0 will aggregate cascades of effects on one pair
I'm do all for make Creative Labs must die
In wish list , to 4.0 , make cascade effects on one pair , cascade effects this when each effect can do used seveal )
Oficial link on MediaFire : https://www.mediafire.com/file/wbmdgh373f07vj … Router.zip/file (this link will refreshable)
I closed the source code , in next I will think of something , but source code will open , but only not on GitHub , I hate when my forced do so what want resource , I am the master of my decisions , and so will be always )
All my projects herre https://www.mediafire.com/folder/wlg1wfnozwddh/Softwares )
