First post, by Kahenraz
Is there any autoexec.bat mechanism for DOS prompts in Windows 98?
Reply 1 of 4, by NeoG_
Can you give an example of what you what to do, maybe there is another way to do it
Reply 2 of 4, by Disruptor
command /k batfile.bat
Reply 3 of 4, by Kahenraz
I want doskey.com to always run whenever I open a command prompt so that I can have tab completion and command history.
Reply 4 of 4, by jakethompson1
Kahenraz wrote on 2026-09-07, 06:04:
If you put doskey in your actual autoexec.bat, each opened DOS prompt will have doskey. This is the easiest way.
Another option is to customize dosprmpt.pif, so that it executes a batch file, as Disruptor said.
