First post, by enaiel
I am looking for patches for Turbo C 2.01 that will:
  1. Enable the Turbo C editor, compiler, linker and all other included tools run without issues, freezes or crashes on a fast DOS PC.
  2. Enable any binary built with Turbo C to run without issues, freezes, or crashes on a fast DOS PC.
I am not looking for patches to patch binaries that were built with Turbo C unless that is the only alternative.
Thanks in advance!
VIA C3 Ezra-T 1.0GHz / MSI MS-6368 / Voodoo2+ViRGE GX / SBPro2+YMF744+AWE64 / MT-32+SC-50
Pentium III-S Tualatin 1.40GHz / QDI A10T / Voodoo3 3000+GF4 Ti4200 / Audigy+AU8830
Reply 1 of 1, by EZ
Might this be the same issue as the Turbo Pascal 7 issue? For that a simple hexedit replace was sufficient
