First post, by Zup
Hi
I'm trying to have an easy way of creating PCL5, PCL5e and PS3 files, so I tried to install some drivers on Windows 11 x64 connected to FILE. The results so far:
- PCL5 - I tried to install an HP LaserJet IIID so I could generate PCL5 files that had duplex support. There is no support for that printer on legacy HP drivers, and the HP LaserJet III does not have duplex, nor options to install it.
- PCL5e - Installed an HP LaserJet 4+, configured to have duplex. Works fine, but it has a PJL header.
- PS3 - Installed an HP Color LaserJet 8550-PS (it's a commonly used with CUPS-PDF), configured to have duplex. Works fine, with PJL header.
So... any recommended PCL5 only driver that have duplex (HP LaserJet III seems to be the only strict PCL5 printer).
Any guess about how can I get "clean" PCL/PS3 files (those without PJL headers)?
Thanks in advance.
I'm selling some stuff!
