First post, by fix_metal
Hello everyone,
Tonight I tested a game on my 486 which showed totally different experiences when ran via dos or wfw3.11. the game uses dos4gw and needs its CD ROM in place to work.
Falling down the rabbit hole I discovered I had enabled the wfw3.11 pseudo 32 bit access mode (which is simply extended 386 to get over the 1MB dos memory limit later I discovered). Although, being the HDD master and the CD ROM drive slave, performances just drop when started with wfw3.11. Dos is ok instead.
I'm using a GoldStar MIOVLU6-AA VLB [0] card as for I/O on a 486 DX4 with [1] mobo. The VLB was an upgrade from the original Gold Star Prime2C 9425 (no brand) card which was originally bundled with the PC.
Now, the most obvious alternative would be to separate the CD to a different IDE channel..although, the mobo only allows for 2 IDE drives in the bios [2], hinting me it's not supporting secondary IDE channel through bios. I've tested any jumper configuration with both the cards in place with the VLB having the HDD and the ISA having the CD drive attached, but I can't seem to find any rightful combination.
Now I wonder if there are any possibility here. Fwiw the PC is equipped with a sound Blaster pro 2 ct1600 [3], which would benefit a Matsushita drive (if I could get my hands on a working one for a good price). Maybe the only way forward?
I'm open to suggestions. And also curious about how was this handled back in the days, as I was too much of a kid to notice I guess.
Thanks anyone.
[0] https://theretroweb.com/expansioncards/s/goldstar-miovlu6-aa
[1] https://theretroweb.com/motherboards/s/pcchips-m912-v1.4-486
