First post, by Indrid_Cold_
- Newbie
Italian BBS from Grosseto, Italy... reborn! You can connect directly from fTelnet box inside https://timrouter.dns.army/miskatonic/ - demo video @YouTube: https://www.youtube.com/watch?v=nf296NcCgTY
Miskatonic BBS has never been a static project. Its history is a succession of different machines, operating systems, experiments and, at one point, a long disappearance.
The original BBS was created in 2015, running on a first-generation Raspberry Pi 1 Model B. Even in that early incarnation, Miskatonic was conceived as more than a simple message board: it was an attempt to recreate the atmosphere of the classic BBS era while experimenting with inter-BBS networking, ANSI graphics, scripts and external services. The first version was also shaped by the help of other SysOps and developers, including Avon of Agency BBS, Lobo, who contributed custom ANSI artwork, and xqtr, whose add-ons later became an important part of the system.
Around 2016, however, an accident wiped out the original installation together with its configuration, customisations and backups. Miskatonic effectively disappeared.
For several years, there was nothing but the memory of the project.
Then an unexpected piece of its past resurfaced: an old dump of the original BBS. That archive became the starting point for bringing Miskatonic back to life. Rather than simply restoring an old snapshot, the project was reconstructed step by step, using the recovered data as a historical foundation while rebuilding the surrounding environment from scratch.
The first new incarnation ran on a completely unconventional platform: a retired Huawei P Smart smartphone from 2018, without root access, hosting a Debian environment through Termux and PRoot. It was an unlikely machine for a BBS, but it offered something that made the experiment particularly interesting. Through the Android/Termux APIs, Miskatonic could interact with the phone itself: it could flash the device's torch, generate spoken messages using text-to-speech, and display Android notifications when events occurred on the board.
Those experiments eventually disappeared, but the philosophy behind them remained.
In August 2026, Miskatonic entered its third major incarnation. The BBS was moved from the smartphone to a bare-metal Debian GNU/Linux x86_64 server, using a repurposed Dell OptiPlex. The transition eliminated the limitations of the PRoot/Termux environment and returned the project to a conventional Linux server — while deliberately preserving many of the conventions established during its earlier life, including the familiar high-numbered connection ports.
The migration was not simply a matter of copying files. Reconstructing the environment meant recovering old behaviour, repairing broken references, replacing obsolete components and fixing problems caused by the interaction between old BBS-era character encoding and modern UTF-8 systems. Some menu entries pointed to scripts that no longer existed; ANSI drawing characters were being corrupted by double encoding; even the geolocation screen had to be repaired after a local DNS filter silently interfered with the external service it depended upon.
Today, Miskatonic BBS is therefore neither a museum piece nor a simple restoration. It is the latest incarnation of a project that has survived its own hardware, software and history. The recovered dump provided a bridge to the original Miskatonic, while each successive platform — Raspberry Pi, smartphone and finally a dedicated Linux server — added another layer to its identity.
The machine has changed. The code has changed. Much of the surrounding Internet has changed.
The BBS remains.
